Old 09-29-2022, 06:08 PM   #11
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: 60 ft help
Originally Posted by casrak7 View Post
What engine specs and weight of your car?
400 with old school 23 Brodix 10x head, 12.3 ratio and old generation of a Super Stock cam design. full exhaust out the back T400.. 3260 weight
Old 09-29-2022, 11:52 PM   #12
Rory McNeil
Actually, the math shows roughly 6 percent slip
That was a great running car! What was the whole engine combination?
It was a stock 5.0 block, with a 3.25" stroke Eagle crank and rods, with flatop pistons. Cam was a solid flat tappet Comp Cams (.560ish lift, 252@.050 duration), out of the box AFR 185 heads, Victor Jr. intake & 650 DP Holley. Set of cheap 1 5/8" FlowTech long tube headers, Used a Jerico DR4, and 4.88 gears in the 8.8, with 9x29" Hoosier slicks. Dumped the clutch at 62-6400 RPM, shifted at 6800, 7000 at the finish line. Now running a "big bore" 347 SBF, (4.125"x3.25", Dart block), flat top pistons, smallish hyd. roller cam, AFR 185 heads, Parker Funnel Web intake with a Holley 750. Same headers, clutch, but switched the Jerico for a G Force G101A 4 speed, gone a best of 10.01 at 133 mph in my 78 Fairmont (2900 pounds), bracket car, still mid 1.3 60 foots.
NHRA 6390 STK
M/S 85 Mustang
Old 10-06-2022, 01:11 AM   #13
casrak7
Liked 3 Times in 2 Posts
Got in some better air, 260ft da. Went 10.32@131.31, with 6.59 eighth@105.4. 1.43 60 ft. Still need the converter loosened some. Going to run some valve lash loops, and try some thinner oil for the heck of it next time out. Not enough time in the year to send the converter off right now. Maybe get a mid 20.
casrak7 is offline   Reply With Quote
