Old 11-09-2022, 12:06 PM   #11
John Dinkel
Liked 263 Times in 68 Posts
Default Re: ECAE Alternator Belt slipping
Is the belt too long?
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 11-09-2022, 02:32 PM   #12
cad
cad's Avatar
Liked 93 Times in 52 Posts
Hi. The belt adjustment is good, just the pulley is too narrow. I have 2 or 3 others alternators laying around and will need to test fit to find another that is designed correctly.
Clark
Old 11-09-2022, 06:57 PM   #13
FED 387
Liked 333 Times in 180 Posts
personally i would go find "a belt" that fits in both grooves satisfactorily put it on without changing any pulleys start the engine up wing it to 6 grand see if the belt stays on doesn't flip off or slip has enough tension and makes the alternator charge---why bother chasing around for pulleys etc. unless of course you are going for the look --- who cares whether its to thin or too thick as long as it functions properly---FED 387
Old 11-14-2022, 12:18 PM   #14
cad
cad's Avatar
While over at a buddy's place, I checked out his 2 cars both with east coast cs130 alternators. He is using a NAPA brand 25-7335 belt. It rides down in the alternator pulley better. He had 3 spare belts and they all measured .39 and .40. I picked one up yesterday and should do the trick.
Dayco 15330 belt was .44.
Thanks,
Clark
