Old 11-27-2022, 05:45 PM   #1
Tom Meyer
Liked 354 Times in 120 Posts
Default Car Wiring
Starting the task of wiring my car, has anyone had issues with running crank trigger wiring along with the electric fan and water pump wires. Going to chase it thru the frame rail. Thanks Tom
Tom Meyer 5240 SS Stock ???
Old 11-27-2022, 06:08 PM   #2
Ralph A Powell
Liked 225 Times in 136 Posts
Default Re: Car Wiring
Keep Crank Trigger wire isolated and shielded. Don’t take chances.
Ralph A Powell is online now   Reply With Quote
Old 11-27-2022, 08:27 PM   #3
Keith 944
Keith 944's Avatar
They sell a shielded, (grounded) wire so you can do that, I use that, but i still keep that wire separate from all others, especially electrical motors ie. fans and pump, lots of rfi there.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-29-2022, 01:46 AM   #4
CMcAllister
Liked 920 Times in 259 Posts
And alternators.
Old 11-29-2022, 06:59 PM   #5
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
Tom,
We ran our trigger wires through brake tubing under the hood. The tubing, because it is stiffer, allows you to take what ever path you want (you can route it neatly). We have used it for years with no problems.
Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 11-30-2022, 09:06 AM   #6
Ralph A Powell
Originally Posted by dragracerray View Post
Tom,
Ray
Great Idea!!
Old 11-30-2022, 05:26 PM   #7
NHRA1926
NHRA1926's Avatar
Liked 232 Times in 69 Posts
Try this. I installed this when I up graded to the MSD Grid system. Removes any electrical noise interference.
https://www.jegs.com/i/MSD-Ignition/...30MSD/10002/-1
NHRA1926 is offline   Reply With Quote
Old 11-30-2022, 06:31 PM   #8
Keith 944
Keith 944's Avatar
I don’t think that would help the interference from electrical motors to the crank trigger wires. That being said, I also use that to keep a “clean” input from the main power
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 12-01-2022, 04:08 PM   #9
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I have my fan, water pump, and alternator wires bundled together and running along the intake manifold where it meets the passenger cylinder head. My throttle stop wires and crank trigger pickup are not part of the bundle, but run right along with that bundle on the same path.
I'm not going to tell you it is a recommended practice or even a good thing to do, but I have never had an issue with it (that I know of).
S/ST 51
S/C 53
