Old 12-01-2022, 07:55 PM   #11
voltdr
Liked 100 Times in 51 Posts
Default Re: Onan 7kw generator problem
What model # is your generator?
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 12-02-2022, 09:12 AM   #12
SGSST109E
Liked 126 Times in 61 Posts
HGJAB I believe. I finished all the work, adj. valve gave it a tuneup and cleaned it up. Its back in the trailer and runs great. I welded wing nut to the ends of the torgues screws so they could be turned by hand.
SGSST109E is offline   Reply With Quote
Old 12-04-2022, 03:11 PM   #13
cad
cad's Avatar
Liked 93 Times in 52 Posts
What ended up being the cause of the issue besides the belt? Was the rotor turning when you pushed start??
--Thanks
Old 12-05-2022, 08:16 AM   #14
SGSST109E
The belt was the main issue so the rotor wasn't turning so it would shut right off.
