Liked 66 Times in 31 Posts
I can't get the fuel pressure to display on my data log. I only have 11 sensors recording on the log dashboard and when I view the run the fuel pressure is not there. Any advice is welcome.
Liked 502 Times in 130 Posts
Shouldn't be too tough:
These things follow your laptop #1 go to your laptop and see what you have setup there for your datalog list on the laptop. Its likely the 11 your are seeing. If fuel pressure is missing add it, save hook up laptop to car, obviously power to fast and reconfigure the internal data logger. Now you can do a test datalog. I first go to the dashboard here you should see your FP added. Note car does not need to running for this, just power to Fast. Do what you need to do to get it your datalogger armed in my case brake pressure then trip it in my case throttle position, I will vary the throttle position a few time watching it on the dashboard, let it time out 20 seconds or so, and then pull the datalog like normal. Hope this helps. I had to go through this back in the summer, when I screwed up my laptop configuration! Heres what our world champ reminded me: Any time you make a change to data log configuration you have to select configure internal data logger. Eric
Eric Merryfield 1883 STK Last edited by Eric Merryfield; 12-23-2022 at 10:10 AM. Reason: spelling |
Thanks, I can easily trigger mine with the throttle and check it after re configuring it. Mine triggers with 60% throttle.
