Liked 11,010 Times in 2,263 Posts
I still have calls from before Indy 2022 that I’ve had no response from FAST
Liked 66 Times in 31 Posts
I was having a data logger issue and I talked to them every day for a week and no problems. You might try emailing them. I all ways call early in the morning if that helps.
The only problem I had was the car would not start, no biggie. We were just trying to go to Bowling Green then to the US Nationals.
Robin Lawrence help me fix my FAST issue. I’m thinking cost of going to a race without visible tech support would be a great way to waste a trip and a race. So I spent about what it cost to go to the race for the new Holley system.
Liked 81 Times in 45 Posts
Which system did you decide to go with? I will be needing one for my SSGT car soon.
Thanks and Happy Holidays |
When I get back to the shop I’ll post Robin’s recommendations. I think they’re Hemi specific for the injector harness and coils packs.
554-113 HP ECU
558-308 Main Power Harness 558-116 Main Harness 554-122 Coil Drivers 554-100 NTK 02 Sensor Hope this helps |
Liked 1,071 Times in 378 Posts
Hey Larry,
If you don't want to have to get the laptop out every time you change the 2 step settings I sell these. You might not be using a two step, but if you are,and your new harness has a power tap (it probably does) it will plug right into it. Or for the guys running a Dominator it plugs right into the J4 port of the ECU. Robin or I will have to add an advance table to your tune to make it operational, but they work just like the MSD ones. I had an engineer up in Detroit make them up for me. Whatever your "Base" setting in your Rev limits are, this will allow you to add up to 1100 RPM of adjustments. Pm me if your interested.
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 12-26-2022 at 11:05 AM. |
