Old 12-31-2022, 08:54 AM   #11
SGSST109E
Liked 126 Times in 61 Posts
Default Re: Best transmission fluid?
I have always used Type F no matter the brand.
SGSST109E is offline   Reply With Quote
Old 12-31-2022, 04:14 PM   #12
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
The John Deere fluid was recommended to me by Alex Denysenko he said when he ran type f he had to change it every 50 passes and the the John Deere was poured in when trans was freshened up and did have to change it until the next freshen up. So that’s what I went to with good results.
Terry
outlaw is offline   Reply With Quote
Old 01-03-2023, 05:54 PM   #13
jmantle
Liked 172 Times in 81 Posts
Originally Posted by Joe Strunk View Post
So,
I have a Question regarding Type F fluid
I have cases of old Type F in round cans, anyone care to share info if it's still good to use after all these years or what to do with it? Some in basement some in back of garage stacked high, still in original boxes.
Thanx in advance
Shake the can first, some additives tend to settle out.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 01-04-2023, 03:27 PM   #14
Future Super Stocker
Smile Re: Best transmission fluid?
Fram / Carquest or Valvoline Dexron VI full synthetic at Advance Auto works perfect for me. I wounder if some brands come from the same tap with their own name on them.
Future Super Stocker is offline   Reply With Quote
Old 01-04-2023, 04:10 PM   #15
Bob Don
Bob Don's Avatar
Liked 903 Times in 192 Posts
ATI Super F synthetic 20 weight
Bob Don 128 SS
Old 01-04-2023, 07:54 PM   #16
Blackgar
Liked 48 Times in 18 Posts
I still buy motorcraft Type F
Blackgar is offline   Reply With Quote
Old 01-04-2023, 08:55 PM   #17
Rob Petrie E395
Liked 216 Times in 77 Posts
Has anybody tried the ATI super F ULV 0W-8 vs the regular 20w trans fluid?
Old 01-05-2023, 02:52 AM   #18
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
I use Motorcraft Mercon LV with no problems.
Dave Noll, EF/S ,?/SA 6526
Old 01-05-2023, 10:37 AM   #19
Rsmith38
Liked 28 Times in 15 Posts
I have been using it in the Jeep for a couple of years. 315 HP at 3305 lbs. No problems - Never did a back to back but its not slower!
Rsmith38 is offline   Reply With Quote
Old 01-05-2023, 02:00 PM   #20
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Originally Posted by Jeff Stout View Post
I swapped to John Deere on my bracket because converter was way to loose on nitrous. It tightened up 200 rpms on the graph.
The replay tach on stocker showed about 150rpm drop on converter and it has metric 200.
Which trans fluid did you switch from? Just curious where the difference is from and to
