Old 01-11-2023, 01:12 PM   #31
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Best transmission fluid?
Originally Posted by Jim Hawkins View Post
This is what I use in the race car, service truck and the Duramax truck. A friend of mine works on Allison transmissions and says it is a extended interval oil, 200,000 miles. Works for me.
That's pretty much in line with the information I have found. It might not be 'better' than anything else under normal conditions and regular maintenance, but it will not break down under extreme heat and/or for a longer period of time than other fluids.
S/ST 51
S/C 53
Old 01-11-2023, 09:18 PM   #32
jmantle
Liked 172 Times in 81 Posts
Originally Posted by Lenny5160 View Post
I'm surprised to not see a mention of Allison TranSynd in this thread. It seems to be the "gold standard" in the bracket/Super-class world.
That's what I recommend for my customers that burn the paint off the torque converter, it does stand up to heat very well as most synthetics will. I've tried Transynd, type F, Dex 3, Dex 6, tractor fluid and see very little difference in performance. I'm now running Dexron ULV, it's a low viscosity fluid for the newer 8 and 10 speed and it does seem to be a little quicker. Less drag?
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
