Old 01-15-2023, 09:55 PM   #1
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Default Guys who removed their stock gas tank?
What material did you use to cover the hole and install your fuel cell??? According to NHRA rule book....(Where OEM gas tank is in the trunk floor, area occupied by OEM
tank may be replaced with material equal to or heavier than OEM
floor.) Sorry this may be a dumb question......
Rose Racing is offline   Reply With Quote
Old 01-15-2023, 10:59 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: Guys who removed their stock gas tank?
i went to my local metal supplier and got 18G to fill the holes in the florring and engine compartment.
Old 01-15-2023, 11:19 PM   #3
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
The gas tank didn't leave a hole in the floor, it was mounted underneath the floor boards.
Old 01-15-2023, 11:26 PM   #4
Rory McNeil
Actually, on many Ford unibody cars like Mustangs and Fairlanes, the factory gas tank drops into a large rectangular hole in the trunk floor, and the top of the gas tank IS the trunk floor.
NHRA 6390 STK
M/S 85 Mustang
Old 01-16-2023, 12:24 AM   #5
Kenney Kelley
Liked 72 Times in 36 Posts
In that case could you just cut the top of the gas tank off and use it to fill in the hole and it would bolt in where the original tank was plus i think it had ribs in it for strenght and then place the fuel cell on that. Just a thought.
Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 01-16-2023, 06:42 AM   #6
MR DERBY CITY
Liked 8,046 Times in 1,527 Posts
Kenney Kelley
Cut the top of the gas tank ..GEEZ. I don’t think so ……
Old 01-16-2023, 11:14 AM   #7
Mark Ugrich
Liked 71 Times in 38 Posts
Kenney Kelley
Actually i’ve seen just the opposite. Section the tank and use the lower half. From under the car it looks like it still had the stock tank, then mount the fuel cell inside on top.
Old 01-16-2023, 12:09 PM   #8
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Guys who removed their stock gas tank?
Any time you cut up a gas tank, an explosion hazard is created. The best bet would be to fabricate a replacement panel from 18 gauge steel that would replace the OEM tank. Be sure the tank is outside when any cutting or welding is being done in the shop. Fumes can travel quite a ways and carry a flame back to their source and do damage.DON'T cut or weld on the gas tank itself.
Old 01-16-2023, 12:24 PM   #9
Mike Gray
Mike Gray's Avatar
Liked 693 Times in 201 Posts
GAS TANK
Must be correct year, make, and model for car used, with stock fuel inlet and outlet locations. Must be in stock location; fuel line and pickup may be resized. Fuel cell permitted; maximum capacity 16 gallons. If fuel cell is used, OEM gas tank must be removed, and a firewall of minimum .032-inch aluminum or .024-inch steel must be installed to totally seal driver compartment from fuel cell. Trunk floor may be modified to accommodate fuel-cell sump.
STK
Section 11A, page 5 Stock Cars
Where OEM gas tank is in the trunk floor, area occupied by OEM tank may be replaced with material equal to or heavier than OEM floor. If OEM gas tank is used, it must remain unaltered.
I read that to say if you use a fuel cell the gas tank must be removed. In the Ford a new trunk floor needs to be used and it can be modified for fuel cell sump.
Mike 7570 A/SA
Old 01-16-2023, 12:45 PM   #10
Kenney Kelley
What i was talking about how i would cut the top off the gas tank was run a nitrogen purge in the tank for about an hour then put an O2 Meter ( Oxygen Analyzer) in the tank to make sure the gas fumes are gone. I've seen it done where you run a hose off an exhaust pipe and purge the tank that way also. Then and only then would i cut the tank I'm sure you would do the same.
Kenney Kelley
