#101 |
Liked 34 Times in 10 Posts
I’m confused, don’t we all have to play by the same rules? The rule isn’t taking anything away from you alone, we all have to take them down. Isn’t Stock/Super Stock more about drivers and less about driving aids anyway? If you can’t hit the bottom bulb without a blinder, there is plenty of room in the .90 classes, where you can have all the driving aids you need.
#102 | |
Liked 1,924 Times in 432 Posts
Permanently attached simply means it must require tools to remove or install. They can be moveable and adjustable. The ones in the orange Camaro are mounted to the roll bar, but they're moveable just exactly like a sun visor. They're actually about the size of an index card. They WERE perfectly legal according to the rule book, and went through tech dozens of times. You fold the one you need down, when you're in the water. And you fold it back up when you're on the return road. Of course, what I'm talking about is simply a small device to allow you to block only the top two bulbs on your side of the tree. What I have seen, and I agree, they're astoundingly unsafe, are all sorts of devices, attached to all sorts of objects. I've seen guys in the pits with what looks like a rural parcel mailbox taped on their helmet. It literally blocked his view of the entire passenger side of his car. He might as well have painted half of his windshield, all of the rear window, as well as all of his passenger side glass, black. Just the idea of needing or wanting something of that nature is bizarre to me, and it's obviously dangerous. I'm sure NHRA is looking for the easiest way out. The easiest way out, requiring the least amount of effort on their part, is to ban everything, for everyone. They're not going to want to measure or inspect anything. And they're certainly not going to police blinders in the pits. Too much work. So, as per usual, the screw ups ruin it for everyone, and the regular people are unfairly punished.
Alan Roehrich 212A G/S |
#103 | |
Liked 806 Times in 246 Posts
#104 |
Liked 109 Times in 32 Posts
Many comp cars are pushed making the driver of the car essentially responsible for where the car and golf cart are headed. Throw in a hood scoop with the blinder and the view from a comp car seat is significantly less than that of a stock or SS’er when navigating the pits.
Drew Whalen Stk 3186 |
#105 | |
#106 |
More often than not anymore, Comp cars and Top Sportsman cars are being pushed not pulled so the driver is the guy dictating where the car is going, not the golf cart. Based on that, he's the guy with the blinder and humongous hood scoop in his line of vision making the decision on where to go. Based on that, these cars are way more likely to hit something.
#107 |
Liked 282 Times in 103 Posts
With the latest clarification:
https://www.nhraracer.com/content/ge...715&zoneid=132 I read this and it seems like you could protest someone if you lose and saw your opponent using a blinder. I could really care less on this one.Same thing as at the scales.If I am bracket racing someone and they come up 5 pounds light at the scales,I could care less.I don't weigh if I lose unless specifically instructed to. This could lead to some exciting racing this year.Car A wins the round,but upon further review at the replay booth,Car B is reinstated because of a blinder penalty and an automatic first down. |
#108 | |
Liked 100 Times in 51 Posts
Dan
Dan Foley SC 4698 |
#109 |
Guest
Posts: n/a
I see cars being pulled out of the scales at Phoenix to be inspected for blinder infractions…
Just don’t use a Coors twelve pac box to make one.. It appears some here are afraid of the blinder. Good reason to have one in the car. We still need a - (Dislike) tab! Last edited by Barry Polley; 01-21-2023 at 12:20 PM. |
#110 |
Liked 68 Times in 41 Posts
![]() I could see that. How many times have you seen or heard cars in the pits testing their two steps or transmission brake. And who has never checked their converter stall speed in the the pits.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
