Old 02-22-2023, 02:38 PM   #11
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Default Re: 1963 - 1979 Vette four link install.
FWIW we have chosen to stick with ladder bars in the gen 3 we run heads up stuff with. Car has been 1.08 60' NA with a 29.5x10.5 slick.
sst7250 is offline   Reply With Quote
Old 02-22-2023, 03:31 PM   #12
SSDiv6
Liked 1,595 Times in 583 Posts
Build a 1978-1980 Malibu just like the SRD-built car raced by Larry Kopp.
Old 02-22-2023, 07:23 PM   #13
Woodfin
Liked 288 Times in 109 Posts
SS d6. I like your comment about the G body. I know from experience those are good packages.
Old 02-22-2023, 07:26 PM   #14
Woodfin
SST 7250, I like your comment about a ladder bar. I know from experience they work very well. My reason for asking about a four link in the Vette was because of the limited space available. It is a non-issue because I have scratched the Vette idea.
Old 02-22-2023, 09:16 PM   #15
4543
Liked 647 Times in 140 Posts
Larry, How much tire do you need? My 71 H/SA has gone 1.36 on a 9” Hoosier. My 12 bolt is one of the first conversions done when NHRA began allowing them in stock. Nothing fancy, no 4-link. I know before it got crazy with some of the setups allowed in stock others were doing the same thing and making them work. Mike McMahan 2543 H/SA
4543 is offline   Reply With Quote
Old 02-22-2023, 09:43 PM   #16
Woodfin
Mike, it will need to run 5.90's - 6.0's in the 1/8th at around 2900 pounds with driver. Thus, around 725 horsepower. The tire size is not so much an issue as the rear assembly strength at that performance. I think a 30 x 12 tire would be plenty. And remember this is a manual trans deal.
I realize this post is all over the place, but I have found 1975 Vette 10 miles from my shop that will check out tomorrow.
Someone mentioned cutting the rear floor out of the body. Have you seen that done?
Old 02-22-2023, 10:36 PM   #17
Ernie Neal
Ernie Neal's Avatar
Liked 328 Times in 80 Posts
[QUOTE=Someone mentioned cutting the rear floor out of the body. Have you seen that done?[/QUOTE]
Larry, I have cut up a C4
http://classracer.com/classforum/sho...light=corvette
Ernie Neal
SS354
Old 02-22-2023, 11:25 PM   #18
Woodfin
Ernie, I had forgot about that project, thank you for the link. Tomorrow I am looking at 75 model for possible project.
Old 02-22-2023, 11:31 PM   #19
Woodfin
This "may be" the engine and power level. A 408 LS engine [4.030 bore x 4.0 stroke] Fully worked LS3 heads, methanol carb, around 725 horsepower with upper RPM level of around 7500. With the proper clutch setup will a 12 bolt hold up?
Old 02-22-2023, 11:40 PM   #20
Woodfin
Ernie, where did you get the four link forward frame bracket?
