Liked 115 Times in 29 Posts
***CAR IS SOLD*** Thanks Class Racer
1981 Chevy Malibu Wagon Built for 2021 racing season Multiple race wins 2022 Box class championship (foot braking) 182 runs on fresh engine in 2022 265 total runs on car starting 2021 Car runs 10.90’s / 11.0’s quarter mile, 6.8’s – 6.9’s 1/8 mile Drop in a legal 305 or 350 & go Stock Eliminator racing Reupholstered seat Reupholstered headliner Reupholstered sun visors New carpet Autometer gauges Art Morrison 6 pt. bar with driver & passenger swing-outs RCI Platinum camlock belts (good thru June 2023) Double adjustable upper & lower rear control arms New front springs Competition Engineering adjustable shocks front & rear HR Parts n Stuff rear sway bar Centerline Pro 15 x 8 rear wheels Centerline Pro 15 x 3.5 front wheels Hoosier 27” front tires Hoosier 18210 30 x 9 radials (C07) Optima battery Powermaster 75 amp mini alternator Powermaster Ultra Torque 9400 starter Electrical relay panel installed underhood Schoenfeld 1.75” headers Manual steering, S-10 gear Engine 383 Stroker, internally balanced, 12:1 Eagle forged crank, one piece rear seal 6” Eagle rods DSS forged pistons, +4cc dome Total Seal rings King bearings Howards hydraulic roller cam Comp short travel hydraulic roller lifters Trick Flow pushrods GM Fast Burn aluminum heads Cometic MLS gaskets 210cc intake / 78cc exhaust 64cc chamber 2.00” / 1.55” valves PAC beehive springs, seats, retainers & keepers ARP screw-in 7/16” studs COMP Ultra Pro Magnum XD roller rockers COMP stud girdles Edelbrock Super Victor intake manifold SFI flex plate ATI Super Damper Moroso pan Cooling Meziere water pump Aluminum radiator Dual Flex A Lite electric fans Transmission Munsinger 8” converter, freshened by A1 TH350, Turbo Action manual valve body 2.75 low gear Deep cast pan B&M cooler Braided/Teflon cooler lines Turbo Action Cheetah shifter Strange 3.5” chromoly driveshaft with chromoly yoke & 1350 U-joints Rear axle Mark Williams 12 bolt 35 spline axles Profile milled spool Richmond Pro 4.33 gears Ford type ends, no C-clips 5/8” studs Billet caps Strange chromoly yoke Brakes Aerospace Components 4 piston discs front & rear Manual master cylinder, corrected pedal ratio ½” front studs Ignition MSD Digital 6 Plus box MSD Blaster HVC II coil (8253) MSD Pro Billet distributor MSD Cap-a-dapt MSD Wires 2-step off brake pressure switch Fuel System RCI aluminum 5 gal. cell with rollover valve Holley black pump Holley pre-filter WIX spin-on post filter -8 line cell to carb (aluminum hard line along frame) Quick Fuel BDQ-850 carb Holley regulator Spares/Extras Complete set of spare wheels & tires -Centerline Warrior 15 x 9 rear -Centerline Warrior 15 x 3.5 front Hoosier 27” fronts Hoosier 18210 30 x 9 radials (C07) (zero runs) Complete 1978 nose panel, grille & trim (painted silver) Fresh TH350 identical to what’s currently in the car (zero runs) American Racing Headers 1.875” stainless full length headers (zero runs) New rear bumper filler panels $19,000 Contact: FiveO9-five39-I7six7
Mike Merk Last edited by Mike Merk; 04-07-2023 at 03:19 PM. Reason: Sold |
I haven't decided, have a couple of tentative turnkey deals pending. I'll respond here if/when I have an answer on that.
Mike Merk |
