Old 04-06-2023, 06:18 PM   #1
Bucksnort
Liked 2 Times in 2 Posts
Default In Search of Doug Nash 18 Spline Chevy Snout Input
Have an early Doug Nash with 18 spline with Chevy snout.Anyone have an input shaft for sale,can be good or damaged.How about the length difference between the Chrysler and Cheny snouts.
Bucksnort is offline   Reply With Quote
Old 04-07-2023, 12:24 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: In Search of Doug Nash 18 Spline Chevy Snout Input
Chevy input shaft is 6.66 inches long--- MOPAR input shaft is 8.57 inches long--what are you trying to do??? if you are trying to lengthen the shaft weld an extension onto a chevy input and turn it down to the MOPAR dimensions
Old 04-07-2023, 11:36 AM   #3
Bucksnort
Wanted one to align my clutch.Did find a dummy 18 spline but has the Mopar nose so it will not fit in my pilot bushing.Going to a friends today to turn down the snout to Chevy size.Thanks for those dimensions,may have to cut it down.Have an ACE clutch with 6 pressure adjustments that I have to drill bellhousing for access.Just trying to be as accurate as I can figuring out the drill point.Did indicate the bellhousing.
Old 04-07-2023, 12:49 PM   #4
FED 387
CHECK your PMs--FED 387
Search this Thread:
Advanced Search
