Old 04-15-2023, 11:15 AM   #1
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Default 9" vs 12 bolt.
Could switching from a 12 bolt with a light spool to the Ford be 6-8 slower?
Old 04-15-2023, 10:57 PM   #2
Liked 1,908 Times in 427 Posts
Default Re: 9" vs 12 bolt.
Apples to apples, the Ford stuff is heavier, and the Ford has a less efficient hypoid angle, so it absorbs more power there as well. There could be a multitude of other differences, in component weight, bearing drag, etc. Is it possible for it to be 0.06 in the quarter? I suppose. Depending upon the rest of the combination. There's definitely a reason Mark Williams and other companies make really expensive stuff to run a 12 bolt Chevy in a 9" housing.
Old 04-15-2023, 11:08 PM   #3
tommy d
tommy d's Avatar
I read 30lbs heavier and 3% h.p. loss due to increased friction. Figured you guys would know for sure. Thanks for the response.
Old 04-17-2023, 09:08 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Many years ago my uncle owned one of the Defrank and Cohen Hemi 'Cudas. we would always put the 12 bolt axle under it for class ,heads up or record runs . I seem to remember .05-.08 difference .
Both were light weight in their day.
Old 04-18-2023, 12:45 PM   #5
Jim Caughlin
Liked 805 Times in 245 Posts
I don't think that Strange developed the 12 bolt drop out center section that fits into a 9" housing for the fun of it.
Jim Caughlin is offline   Reply With Quote
Old 04-18-2023, 05:00 PM   #6
SSDiv6
At one time, there was also a Ford 8.8" dropout to use on the 9" housing made by Chris Alston ChassisWorks. The 8.8" has the same load and drag characteristics as a 12-Bolt.
Old 04-18-2023, 06:05 PM   #7
Ralph A Powell
Liked 226 Times in 137 Posts
Yes Strange did develop the 12 bolt drop out. The did it for Ford racing as Ford wanted to run it on the restrictor plate tracks. Ford tested it on the cup cars but NASCAR wouldn’t approve it. Strange was building all the 9 inch’s Nodular case’s for Ford. Ford did not have a source to pour nodular after they shut down the Flat Rock Casting Foundry in late 1981. Strange also made the High Strength Steel Case that Ford was using in NASCAR up to the end of the 2021.
Ralph A Powell is online now   Reply With Quote
Old 04-19-2023, 01:39 PM   #8
richie 2
Liked 205 Times in 93 Posts
is it popular today in SS? strange 12blt case/9'' housing...
Old 04-19-2023, 01:49 PM   #9
Dirk Olson
Liked 172 Times in 46 Posts
Better gear selection with the 9 bolt. and using a dewco center section with a 9.5 ring gear starts to level the playing field. Given the ease of gear change out, gear selection, it would hard to go to the 12 bolt unless class dictates it.
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 04-19-2023, 02:28 PM   #10
FED 387
Liked 333 Times in 180 Posts
DEWCO is great stuff only problem is Don the DEWCO owner has/had serious health problems might have a problem getting product---FED 387
