Old 04-19-2023, 05:48 PM   #11
Jim Caughlin
Liked 805 Times in 245 Posts
Default Re: 9" vs 12 bolt.
Originally Posted by richie 2 View Post
is it popular today in SS? strange 12blt case/9'' housing...
lots of them
Jim Caughlin is offline   Reply With Quote
Old 04-20-2023, 07:09 AM   #12
james schaechter
Originally Posted by Dirk Olson View Post
Better gear selection with the 9 bolt. and using a dewco center section with a 9.5 ring gear starts to level the playing field. Given the ease of gear change out, gear selection, it would hard to go to the 12 bolt unless class dictates it.
I changed from a 9 inch to 9.5 inch Gleason set up. These were pretty common pro stock set ups years ago before they moved on to bigger stuff. Much more efficient than the standard 9 inch
James Schaechter 3163 STK
Old 04-21-2023, 01:42 PM   #13
Race Clean
Liked 129 Times in 53 Posts
A buddy used one of those 12-bolt drop out pieces many moons ago in a SS application.
He used up gears like crazy, that lead me to believe the performance advantage aspect somewhat disappeared, it was a heavy car
and the Aluminum 3'd member maybe was flexing?
Stop global whining
Race Clean is offline   Reply With Quote
Old 04-21-2023, 03:39 PM   #14
Ralph A Powell
Liked 226 Times in 137 Posts
A good test would be to a loss test on the 9” nodular vs the High strength steel that Strange manufactures for Ford NASCAR program the HS case is 3 lbs lighter that nodular and about 30 % stiffer. According to Bob Stange so it hold everything in place. I don’t believe an aluminum case is as strong as the Ford nodular with the modified tail bearing, the Daytona pinion support and a load bolt to support the ring gear.
