Old 04-25-2023, 06:43 PM   #11
weedburner
Liked 20 Times in 16 Posts
Default Re: Tire Help for Heads-up Manual Transmission Class
Originally Posted by Jim Caughlin View Post
Stick to basic 'meat and potatoes' components that have been working for Stock class cars for years, Soft Lock, alum flywheel, G101 and the 10 x 28 should be plenty of tire to get you well into the 9 second range. Run the clutch as loose as you can get ways with and oh yeah, don't use the clutch to shift.
Coyote Stock is a sealed engine NMRA class that requires a minimum 10" dia single disc diaphragm clutch.
Grant
Grant
website- http://ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!
weedburner is offline   Reply With Quote
Old 04-25-2023, 11:10 PM   #12
Rich osmond
Correct, and a “Diaphragm Pressure Plate assembly is required”.
Rich osmond is offline   Reply With Quote
