Liked 3,228 Times in 982 Posts
SOLD Thanks ClassRacer
Purchased new in March 2021 from Trailers of the East Coast and have only used for transporting to Gainesville for two test sessions, the Galot D2 race last September and the Baby Gators. Originally purchased 24 ft aluminum due to plans to pull behind gas Class A and was trying to keep weight down. Ended up buying a Transit Ecoboost based MH so going a different direction and need a 28-32' with bathroom package to pull behind a 2500/3500 truck. This trailer has the 60" tongue for towing behind motorhome. Below are the other specs, only drawback is the 32" entry door but is wide enough to get the scooter in and out. I've added a couple of anchor points to secure the scooter but no other changes. Weighs only 2700 pounds! Easy pull behind almost any 1/2 ton or Class C motorhome. • All-Aluminum Construction, Integrated Frame Design • Front Style: Flat Front w/Cast Corners • 2″ x 6″ Integrated Frame (24′) • 16″ O/C Floor & Roof Studs • 16″ O/C Wall Studs • Screwless .030 Bonded Sides • One Piece Aluminum Roof • Axles: 2-5.2K Braked Leaf Spring Axle w/ 4″ Drop 15" Aluminum wheels (225/75) • 24″ Stoneguard • 2 5/16″ Coupler w/Safety Chains • 5000lb Center Jack w/Foot • White Vinyl Faced Luan Walls • 3/4″ Water Resistant Decking • Interior Cove Trim • 3″ Exterior Trim • (2) Dome Light w/Switch • Exterior LED Lighting • Plastic Salem Vents • (4) HD 5,000# Recessed D-Rings • Beavertail Construction • HD Rear Ramp w/Spring Assist w/Aluminum Hardware • Large Side Door with removable inner fender to easy egress from car PM for pics or other info. Title in hand, located in Savannah GA area and price is $17,500/OBO __________________
Jim Carter 2340 Super Stock 2340 SST/2340 Stock Set another place at the table Last edited by jmcarter; 06-20-2023 at 06:58 AM. |
