Old 06-15-2023, 11:27 PM   #1
kevinlc
Default The dreaded drag radial wobble
Looking for pointers on how to fix my issue. 68 dart with stock front suspension and four link rear. BB motor with 821hp and a 727. The tires are Goodyear 31.5 x 31 x 15 with 18psi. Car makes it to the 1/8th mile then the steering wheel starts moving left and right and the car wobbles really bad. Ran bias tires for years and no issues. Switched to radials and adjusted the shocks and this happened. Any thoughts on how to fix this. Thanks for the advice.
kevinlc is offline   Reply With Quote
Old 06-16-2023, 07:13 AM   #2
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
Default Re: The dreaded drag radial wobble
How much caster do you have? Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 06-16-2023, 07:52 AM   #3
Mark Howes
Liked 80 Times in 28 Posts
No Fun!
Having been there and done that with different cars over the years I can tell you that many answers are found in the front end not the rear.
The lower psi of the bias ply masks underlying issues already in play. I have seen the following cause radial wobble....
* Bad front shock
* Bad rear shock
* Loose Idler arm
* Cracked steering box mount
Hope you find it easily
Mark Howes is offline   Reply With Quote
Old 06-16-2023, 09:20 AM   #4
novassdude
Liked 136 Times in 49 Posts
do you have radials front and back? Mixing them made my car drive terrible on the top end.
novassdude is offline   Reply With Quote
Old 06-16-2023, 09:43 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Anti roll bar might help with the 4 link. Try running the same pressure in the radial as the bias for a staring point. I run mine a 12 psi and have minimal problems with the wobble. Make sure everything is tight in the suspension and no slop or loose bolts. Radials need to dead hook. No wheel speed as some call it.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 06-16-2023, 10:30 AM   #6
kevinlc
I do have bias front tires. There on a four inch wide wheel and an anti roll bar in the rear. Front end was setup for racing but that was a long time ago and I don’t remember the specifics.
Old 06-16-2023, 01:44 PM   #7
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Like said above - anti roll bar does wonders. A must have with big radial tires.
Old 06-16-2023, 03:00 PM   #8
kevinlc
I do have an anti roll bar. It’s not helping.
Old 06-18-2023, 05:31 PM   #9
kirk
Liked 5 Times in 4 Posts
I had a similar problem on my old third gen Camaro...... put a steering stabilizer on it and never happened again. I had to make some mounts, but wasn't to much trouble. I don't remember what the original application was for the steering stabilizer, but it looked like a standard shock.
kirk is offline   Reply With Quote
Old 06-19-2023, 08:58 PM   #10
Dave Casey
Liked 797 Times in 165 Posts
Don't know if a steering damper is the fix, but the commonly used one is from and old VW bug , and make your own mounts for it
Dave Casey 1330 STK
