Old 06-19-2023, 02:31 PM   #61
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: SFI flexplate mandatory in all v8s Jan 2024
Dave Noll, EF/S ,?/SA 6526
Old 06-19-2023, 04:48 PM   #62
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Just internally balance the rotating assembly then no need to modify the SFI flexplate. Hopefully everyone sees me being a smart *** about this.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 06-19-2023, 05:28 PM   #63
Duane, NOT being a smart*** about this but did you ever see a 301 Pontiac crankshaft?
Old 06-19-2023, 06:34 PM   #64
Duane Eiskant II
Mark, Nope haven't seen a 301 crank. Just adding thoughts to NHRA's thinking. Since this is opening a rabbit hole no body wants to go down
Duane Eiskant
Old 06-19-2023, 07:36 PM   #65
Okay, neither have a lot of guys here, I suspect.
It only has two opposing counterweights, front and rear.
The flex has a big balance weight on it. I wouldn't want to fool around with that bit of Pontiac engineering ;-)
TCI makes an SFI for the 400, which is the same except they are internally balanced.
This brings us to modifying an approved part. I see that this would have to be re-done every three years too. It's not gonna pass re-cert.
I seem to remember hearing that the perp in the Texas was invited to the barn for a look see. Now supposing one comes apart next year, you can bet it's coming apart too.
If they happen to find a modified SFI unit that failed, who do you suppose is going to have to pay that fine?
There are at least three of those 301 cars out there. These are 6 grand in the lights, max combos. What are they supposed to do ?
As my lawyer would say "arbitrary and capricious"
Old 06-20-2023, 09:51 AM   #66
Todd Hoven
Guest
Posts: n/a
Originally Posted by Jim Bailey View Post
Never had any problems with any SFI certified Mopar Flex Plates "UNTIL" I started to two step. We're our own worst enemy. If you two step, the flex plate must become a part of your service routine. Just saying .........
How long ago was that? 90’s ?
Old 06-20-2023, 10:13 AM   #67
Todd Hoven
Guest
Posts: n/a
Did anyone actually investigate the car that sent the shrapnel into Hildago’s car? Was it a stock flexplate? When is the last time an automatic flexplate has come apart at a race and come out of a car? I’ve seen a trans or 2 explode and send parts out.
For years (before I was born) a steel SFI flywheel has been required for any manual trans combo regardless of manufacturer or performance level.
Now after this they want to employ the rule for automatic cars. The rpm and hp range of these engine have advanced quite a bit in the last 40 years. Probably exceeding the limits of stock parts at this point. There is always exceptions to the rules for combos. If you have to rebalance an SFI flexplate for an external balance I’m sure it can be done legally. Probably splitting hairs at this point with that argument, but that is what we do here.
Old 06-20-2023, 10:14 AM   #68
Duane Eiskant II
I agree Mark. Both of my convertors when ordered from ATI were done with the 3/8 bolt size just to avoid this.
Duane Eiskant
Old 06-20-2023, 06:55 PM   #69
Regan Wilson
Regan Wilson's Avatar
Liked 134 Times in 70 Posts
The Flexplate was inspected and deemed a parts failure by NHRA. No fault by the racer it belonged to as it was within the given rules.
Regan Wilson is offline   Reply With Quote
Old 06-20-2023, 09:26 PM   #70
mike britt
Liked 66 Times in 31 Posts
In this case the flexplate did not break or come out. It was still bolted to the crankshaft. What happened was the ring gear welds came loose and the ring gear started coming apart in pieces. I found one piece about 2 inches long by the accelerator pedal in bills car. It looked like a stock flexplate to me, but the rules did not require the car to have an SFI flexplate.
mike britt is offline   Reply With Quote
