Old 06-21-2023, 12:39 PM   #11
nhramnl
Liked 358 Times in 83 Posts
Default Re: The dreaded drag radial wobble
As someone else said, solving the problem can be a major task. If you just want it gone with no drama, switch to Phoenix radials, in the size you need. Call Mike Crutchfield and he will give you the scoop. Bottom line, Phoenix tires work and they absolutely get rid of the wobble.
Old 06-21-2023, 05:14 PM   #12
Bob Sherwood
Liked 388 Times in 60 Posts
Have had that problem several times when putting radial tires from bias - tighten front shocks to keep car from rocking back and forth . should work
Bob Sherwood is offline   Reply With Quote
Old 06-21-2023, 08:09 PM   #13
Cotten
Liked 565 Times in 70 Posts
I'm curious if anyone that was experiencing "wobble" ever tried a set of radial front runners and what the results were.
Cotten is offline   Reply With Quote
Old 06-22-2023, 09:34 AM   #14
kevinlc
Does anyone make a radial front tire with that small a width?
Thanks for all the input and keep them coming. Hope to figure this out.
kevinlc is offline   Reply With Quote
Old 06-22-2023, 10:35 AM   #15
Cotten
I googled "drag radial front runner" and found a mickey Thompson tire that I'm sure is heavy but it would be interesting to try on a car that was having problems.
Old 06-22-2023, 03:06 PM   #16
Race Clean
Liked 129 Times in 53 Posts
Have a buddy that chased this issue in the past for 2 years,changed just about everything on the car..finally talked to a chassi builder (well known to this forum) he asked what tire he was using and then said you cant use that one,use brand /size XX instead wich he did and then problem was gone.
Sometimes it's the easy things,
Stop global whining
Race Clean is offline   Reply With Quote
Old 06-22-2023, 05:27 PM   #17
Oscarf164
Liked 5 Times in 4 Posts
ok, what was the mystery tire brand?
Oscarf164 is offline   Reply With Quote
Old 06-23-2023, 07:23 AM   #18
Terry Drinkwater
Liked 27 Times in 11 Posts
Front or rear tire?
Terry Drinkwater is offline   Reply With Quote
Old 06-23-2023, 07:47 AM   #19
dragracedr
Liked 16 Times in 3 Posts
how wide are the wheels the OP is using?
dragracedr is online now   Reply With Quote
Old 06-23-2023, 09:44 AM   #20
kevinlc
I’m using a 14ā€ wide rear wheel and 4ā€ fronts.
