Old 06-08-2023, 09:17 PM   #11
David Lee
Liked 346 Times in 126 Posts
Default Re: Trans failure question...
Originally Posted by Greg Reimer 7376 View Post
Yes. Second time only, left lane. Ended my day nice and early. Were you there?
no, but seeing where you live, it was an easy jump.
i am thinking of buying a 2000 era camaro or mustang to have fun there
Old 06-08-2023, 09:24 PM   #12
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
One easy test is with a Line Pressure gauge, Check the pressure in each gear range.
Old 06-09-2023, 08:25 AM   #13
Steve Stasko
Liked 286 Times in 146 Posts
You're correct in your assumption about the Powerglide being easy. I've done 727's, and the Glide takes about half the time.
I broke a 1.76 planetary and it did still lurch when you put it in gear, so a good chance you broke the input. Are you using a stock input shaft? I would upgrade to at least a 300M if so, though a Vasco is best.
If the planetary is good, make sure you check the end play on the gears in it while you're there. I seem to recall there should be .02-.03" between the gear and the planetary housing.
Old 06-09-2023, 11:02 AM   #14
Eman
Liked 133 Times in 76 Posts
Don't know if you're into the diagnosing before pulling. A third option behind input shaft and planetary breaking is pump gear breaking. Just had a friend's car do this. Pressure test would confirm pump operation if you wanted to know before pulling. Not really needed to diagnose as whatever is broken will be apparent when pulled. Shaft can break and leave a piece in the converter.
Old 06-09-2023, 05:15 PM   #15
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Trans failure question...
Several years ago, i had the drive lugs break off the inside of the inner front pump gear.It resulted in a zero oil pressure situation real fast out of the blue. It was in my Chevelle wagon, same engine/trans combo. When i pull the trans and inspect it,I'll know more.
Old 06-18-2023, 09:47 PM   #16
Greg Reimer 7376
Got the trans out of the car. When I drained it and removed the pan, there is a good quantity of aluminum shrapnel in the pan.No large pieces, I don't know if it has an aluminum direct clutch hub, but it's getting a steel one this time around if it needs one. The input shaft doesn't seem to want to come out, but if the splines in the hub failed, that would account for the aluminum debris. The front pump drive lugs were all still there so further disassembly is next. At least now with the new flex plate rule coming in, this would be a good time to change that out as well.
Old 06-19-2023, 12:38 PM   #17
Pat6868
Liked 92 Times in 29 Posts
Pat6868 is offline   Reply With Quote
Old 06-19-2023, 01:46 PM   #18
Steve Grady
Steve Grady's Avatar
Liked 134 Times in 45 Posts
Hi gear clutch hub breakage does not keep low gear and reverse from working.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 06-28-2023, 10:34 AM   #19
Eman
What did you find?
Old 06-28-2023, 03:54 PM   #20
Greg Reimer 7376
Originally Posted by Eman View Post
What did you find?
Seemed like a bit of work here, right about the time the trans broke, the flywheel failure in the stocker that resulted in a rule addition happened, so I ordered a TCI flywheel and figured that when it arrived,I would install my other trans I wanted to try which is a 350. The 327 probably would love the extra low gear because it left like a cannon ball with the 2.08 Glide. The input shaft on the Powerglide didn't break, neither did the front pump drive gear lugs. I dropped the pan and found aluminum shrapnel in the pan, but the rest of the trans doesn't seem too contaminated. The flywheel just came today, as did a new Simpson harness,so it's back to work time. I suspect the failure was planetaries since nothing works. We have a trans with Park and four neutrals. Once the car is fixed,I'll open up the Powerglide and I'll know more.
