Liked 8 Times in 6 Posts
I'll be adding a remote oil filter to my car to make it easier to change, SBC at 7800 at the stripe. Would a #10 line be ok or should I go with a 12? Thanks
Liked 805 Times in 245 Posts
Pretty much every application I have ever seen is #10.
Liked 920 Times in 259 Posts
Pay attention to port sizes, and fitting and adapter IDs.
-10 hose is not helpful if you have parts in the system with 3/8" IDs. |
Liked 333 Times in 180 Posts
Also try to keep your hose and fittings as straight as possible and no reduction in all the adapters and fittings--- NO 90*s if you can get away from it and also watch your radius in the hose--A -12 is better but you might be able to get by with a -10 if you use a low restriction "racing " type filter no OEM Walmart stuff------keep an eye on your oil pressure
Liked 225 Times in 136 Posts
We have always used #12 on all our remote filters fo both Ford and Mopar
| Thread Tools | |
| Display Modes | |
