Old 07-26-2023, 12:26 PM   #11
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default Re: 2 step & pressure switch
I would think a brake lite switch would trigger
at a low pressure Ours is set at 700 psi
David
Willyracer is offline   Reply With Quote
Old 07-30-2023, 11:04 PM   #12
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
Anyone come up with a part number. McMaster Carr has a switch 3427K5, but it is the Buna rubber.
Old 07-31-2023, 09:01 AM   #13
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
I use one from transducers direst p/n TDPS8. adjustable, 250-1000 psi, 1/8 pipe thread. It works perfect, but looking at the data sheet, it has a buna N diaphram. Contact them and ask for something similar with viton.
513-583-9491
SALES@TRANSDUCERSDIRECT.COM
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 08-03-2023, 08:52 PM   #14
SDT1DYI
Liked 455 Times in 147 Posts
Call Folk Race Cars. They sell what's called the Ultimate Brake Pressure Switch. Easy to adjust to different brake PSI requirements. Two wires.
( Has three but the black wire is not used). 150.00?.
Steve Teeter Stk/SS 620
SDT1DYI is offline   Reply With Quote
Old 08-04-2023, 11:23 PM   #15
littlemanjoe
Liked 75 Times in 28 Posts
What brake fluid are you using with these switches?
Thanks,
Mike
littlemanjoe is offline   Reply With Quote
Old 08-04-2023, 11:37 PM   #16
Eman
Liked 133 Times in 76 Posts
I'll have to dig up the part # but I just use a 2 wire brake pressure switch that has pipe threads. Listing is probably for and old Ford car.
Just found my spare switch, it's an S194 from Carquest.
