Old 08-23-2023, 12:44 PM   #1
melvin wellman
Liked 2 Times in 2 Posts
Default 1967 plymouth gtx 440 cylinder heads.
Just curious. With all the heads listed that would need modifications in order to be used, except the 915, I don't understand why the 516 head should not be listed, with the only modification of using the correct 1.74 exhaust valve in place of the 1.60 valve it comes with. I'm sure I'm missing something. But it don't make sense to me.
melvin wellman is offline   Reply With Quote
Old 08-23-2023, 02:07 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 309 Times in 118 Posts
Default Re: 1967 plymouth gtx 440 cylinder heads.
The 915 head is far better for stock, the 516 is an earlier head. A superseding head is typically if not always a newer head.
Paul Precht is online now   Reply With Quote
Old 08-23-2023, 10:56 PM   #3
melvin wellman
Thanks, it was just a little confusing to me.
Old 08-26-2023, 02:02 AM   #4
GTX JOHN
Liked 2,472 Times in 696 Posts
The 915 flows way better in our experience!
You could spend thousands on the 516 and it would
not be any better than a virgin 915.
John Irving
741 Stock
741 Super Stock
Old 08-26-2023, 10:47 AM   #5
melvin wellman
Thanks guy's, I didn't know any better. Thought the valve size was the only difference.
Old 08-26-2023, 02:13 PM   #6
GTX JOHN
The 67 GTX 440 is a pretty good combo especially.
with the 49 state 750 Carb.
John Irving
741 Stock
741 Super Stock
Old 08-27-2023, 11:48 PM   #7
melvin wellman
I thought it might be worth a try. Was planning on using the edelbrock 1407 and it will be a stick shift car.
