#171 | |
Liked 274 Times in 143 Posts
If one really wanted to go the route of running an automatic Neon, I would swap in an A-413 from an earlier front wheel drive car, and do away with the electronics. Last edited by Steve Stasko; 09-06-2023 at 02:02 PM. |
#172 |
Liked 54 Times in 18 Posts
There's an 05 Neon SE on Facebook Marketplace in Hermosa South Dakota for $150. Its a parts car though, no engine or trans, cheap start though
#173 | |
Kinda like the trans in my Buick.
#174 |
#175 |
If there's an "electric solenoid for each gear", couldn't you rig up some kind of electric "shifter" to control what solenoids are engaged and dis-engaged and use it for gear selection and engagement? Just "brain-farting" here.
#176 | |
Liked 376 Times in 201 Posts
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! |
#177 | |
I will add that I have had some in depth conversation with a Chrysler transmission engineer who didn't come out and directly say, but heavily implied that these transmissions were designed to fail. |
#178 | |
Maybe it's time for a Racer to step up and prove that "Chrysler transmission engineer" wrong.
#179 | |
The 125 started life in a 1980 4 cylinder Citation ( X car). It never failed us at the track, but it tended to wear out final drives. It was a bunch of work,.. having to fabricate mounts, a bracket for the TV cable ,and a custom right hand axle of the appropriate length. If the earlier Mopar transaxle is close to a bolt -in deal, I'd go that way. If not, the later one could probably be controlled by a series of switches. Clutch apply could be firmed up, I would think. Light car , 4 cylinder shouldn't cause a lot of grief in that department.
#180 |
Liked 404 Times in 158 Posts
As far as the solenoids go...(I'll try to be brief) Had a 93 f350 with a 7.3 and the e4od. Broke the planetary so I got another e4od out of a 98. Connectors etc all different.(6 planetary instead of 3 planetaries, much stronger too) I wired the solenoids (to test) and ran the wires up to the dash. Put the truck in drive and nothing. Depending on which switch (or series of switches) I went through all the gears as well as locking up the converter. Even went for a test drive.
So, yes it can be done. Hassle? Yeah, a bank of 4 switches that you toggle through going down the track?...that would be interesting to say the least in competition! |
