Old 09-07-2023, 01:16 PM   #181
Default Re: So all of you Mopar guys!
Originally Posted by goinbroke2 View Post
As far as the solenoids go...(I'll try to be brief) Had a 93 f350 with a 7.3 and the e4od. Broke the planetary so I got another e4od out of a 98. Connectors etc all different.(6 planetary instead of 3 planetaries, much stronger too) I wired the solenoids (to test) and ran the wires up to the dash. Put the truck in drive and nothing. Depending on which switch (or series of switches) I went through all the gears as well as locking up the converter. Even went for a test drive.
So, yes it can be done.
Hassle? Yeah, a bank of 4 switches that you toggle through going down the track?...that would be interesting to say the least in competition!
You'd probably have to throw some relays into the mix, too.
Doesn't sound impossible though.
Old 09-07-2023, 02:54 PM   #182
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Kinda like the trans in my Buick.
Bill, are you tuning the Buick thru HP Tuners ? if so, should have some trans tables in there to "adjust" or turn off and on...
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 09-07-2023, 03:02 PM   #183
Billy Nees
Liked 7,800 Times in 1,747 Posts
Yes, I'm using HP Tuners but it's not quite that simple with the Buick. The Cavalier is pretty simple.
Billy Nees 1188 STK, SS
Old 09-07-2023, 03:04 PM   #184
Steve Stickel
Here You go, expensive, but has to be worth it ... https://www.usshift.com/index.shtml
Steve Stickel
1161 Stk
1167 SS
Old 09-07-2023, 03:42 PM   #185
Doug Hoven
Liked 867 Times in 165 Posts
Both cars are relatively simple. The Cavalier sort of just does what it's told. The Buick seems to be a bit more rebellious, maybe even a bit vindictive at times.
1189 F/SA
Defunzalo Racing Enterprises
Old 09-07-2023, 06:53 PM   #186
GTX JOHN
I am not a computer guy.
Could you just monkey with the speed sensor pulse
to trick the transmission on the Neon to shift later?
John Irving
741 Stock
741 Super Stock
Old 09-07-2023, 10:28 PM   #187
John, I'm thinking the short tires would mess with you. RPM would be up, but actual MPH would be down...maybe?
Old 09-07-2023, 10:31 PM   #188
Hi Steve. Ya gotta remember..We're in the dime rocket realm here ;-)
