changed from stock front drum brakes to lightweight front disc brakes and used master cylinder required 1-1/8 bore brake pedal is hard as a rock car does not slow down checked the ratio on the brake pedal measures perfect the car is a 72 dart any help is appreciated
#2 | |
Liked 184 Times in 113 Posts
Have a used once Wilwood Master cylinder for sale. Dan |
Liked 10,851 Times in 2,254 Posts
On our 72 charger when we changed breaks from power to manual the linkage under the dash had to be changed to a different hole to give us more of a mechanical advantage. I want to say the bore in the master cylinder was smaller making it easy to build psi.
Good luck. |
Like Larry said, at least on Fords, the manual brake cars came with a different brake pedal, with a pivot for the master cylinder pushrod closer to the pivot for the pedal itself, for more mechanical advantage. Again, with my Fords, manual master cylinders a re usually a smaller bore, like 7/8" or 15/16" diameter, compared to over 1" for a power brake application.
Liked 886 Times in 238 Posts
As was mentioned pedal ratio is critical .If the car originally had power brakes the ratio was only around 4 to 1 ,a ratio of 6 to 1 is considered ideal . also ,If you are only using discs on the front and retained the drums on the rear ,a master cylinder with a smaller bore will help.
On a disc /drum car I usually use a 1 3/32 bore master cylinder which wit the 6 to 1 pedal usually will yield around 1000 psi with reasonable pedal pressure.
Liked 253 Times in 95 Posts
On my ‘71 Duster, I used an aluminum master cylinder that came on the Volare/Aspens. I have Strange fronts and stock 10” rear drums and factory proportioning valve also from Volare/Aspen. Never a problem stopping or holding the car. You could have a bad brake hose or a stuck caliper. Make sure too use the braided front brake hoses.
George Mirza D/SA 1236 ‘71 Duster 340 |
#7 | |
Liked 84 Times in 21 Posts
All our A bodies have 7/8 or 15/16 Cylinders
The large one would not let my elder legs hold the two step or stop quickly. We try for 7:1 and sometimes redrill the brake petal itself and relocate the master if need on several of our different stockers. Particularly on the two Aspens F Body cars. You will figure it out. PM me if needed.
The rubber fatigues and expands producing
a spongy petal. At a minimum replace the stock lines every few years.
thanks for the info does anyone have the part number for the volarie style master cylinder? would i be better off going back to the stock master cylinder? also i was told to delete the proporting valve all together was that a bad idea?
