Old 09-11-2023, 09:54 PM   #1
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Default Ignition Box Mounting
Where are you guys mounting your ignition boxes on your Stockers? Just looking for ideas. Thank you
Rose Racing is offline   Reply With Quote
Old 09-11-2023, 11:24 PM   #2
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
Default Re: Ignition Box Mounting
I’ve seen a lot of Chevy’s in the passenger footwell. Probably goes with the shorter wiring and don’t get it wet comments. I have a Ford and I think it’s going under the hood when I mount it but like you I’m open for ideas?
Also check out Bobby Fazio video interviews where he shows the interior, under hood and in the truck of a lot of cars, some good stuff there!
Mike 7570 A/SA
Old 09-11-2023, 11:34 PM   #3
6AL is above>
Old 09-15-2023, 04:46 AM   #4
GTX JOHN
Our mopars are mounted behind the glove box
or right below in that general area.
John Irving
741 Stock
741 Super Stock
Old 09-15-2023, 05:42 AM   #5
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Ignition Box Mounting
Good morning to all,
I mounted my MSD on the passenger side toe board. Mostly because its convenient in case I have to service it. MSD recommends that the box/ ignition controls be placed where air can move around it and cool it. That's why they don't recommend putting it a "glove box" or enclosed location.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 09-15-2023, 03:07 PM   #6
GTX JOHN
Behind our Glove box door there is no longer a real actual
glove box or a heater box. It is totally open to air flow.
Sorry I was not clearer. It is protected from weather
inside car and some of outside heat out is mitigated a bit
as we live in Nevada.
John Irving
741 Stock
741 Super Stock
Old 09-18-2023, 11:34 AM   #7
VE6DRW
VE6DRW's Avatar
Liked 43 Times in 14 Posts
IMHO, I put mine on the passenger side underneath the glove box on a hinged panel. Relay switch panel on the topside with all race-related wiring - MSD components on the underside. Coil mounted on the inside of the firewall just above the hinged panel.
Hinged panel allows for easy access while keeping it out of the way when racing. MSD on the underside allows easy access to MSD box settings and RPM chips (if you use them).
Name:	Switch panel top small.jpg
ID:	68593   Click image for larger version
Name:	Switch panel bottom small.jpg
Dave White
NHRA Stock/SS 606
VE6DRW is offline   Reply With Quote
Old 09-18-2023, 06:03 PM   #8
Mike Gray
Mike Gray's Avatar
Dave gets my vote, very nice. Do you hire out? Lol
Mike 7570 A/SA
Old 09-18-2023, 09:16 PM   #9
VE6DRW
VE6DRW's Avatar
I can barely afford myself :-) All for the love of the hobby
Dave White
NHRA Stock/SS 606
Old 09-20-2023, 02:12 PM   #10
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
We did the same. Mounted the shift light dial on the inside of the glovebox door too. We were hesitant to put it on the floor or kick panels with kids and friends riding in the car for warmup and heading to the lanes.
https://www.classracer.com/classforu...7&postcount=84
Andy Friar
Andy Friar is offline   Reply With Quote
