#61 |
Liked 5,138 Times in 1,961 Posts
https://www.dragracecentral.com/DRCS...r2004#indextop
Okay then. I'm confused... Wasn't there a second shootout, when Bob Shaw ran his Seville? He ran in the 12's but didn't end up winning, because it was a CIC race? Maybe I'm thinking of Beard's deal at Columbus
#62 |
Liked 477 Times in 117 Posts
after the first year pat ran a FREE no breakout race on friday night. first year shaw won with the TAXI freemans car i made semis in witch doctor fast guys whined so after that he made it a CIC race from then on ... bob went -217 in caddy in final but took a hit ever round to get there and lost
that clear it up ?? capt
Jack McCarthy 3609 STK "the Captain" |
#63 | |
Liked 239 Times in 94 Posts
Wouldn't fit U unless they switched it's weight as much as new Challengers but the other way. ![]() |
#64 |
I've always thought that this would be a good idea especially if a combo has NEVER been competitively run in competition. But maybe not go all of the way back to OEM HP in most cases. There would have to be some common sense involved. Also, if a combo has EVER received a HP hit IN COMPETITION, it wouldn't qualify.
#65 | |
So if it happens again, do we want a CIC deal? 1 second under trigger? Next year @ St Louis would be centrally located at least...Maybe Tyler and co. would accommodate it. With all the racing available, it might be worth it to travel from the outer reaches. Thoughts , anyone ?
#66 |
Liked 498 Times in 244 Posts
So...
How is the 230/140hp L6 as a combo? In a Camaro. Looks tough... no compression, 1bbl... How's parts availability? Curiosity strikes... |
#67 |
Liked 869 Times in 165 Posts
Billy would know better than I would, being that he played with two different cars with that combo for about 20 years. Some parts are easier to find than others. When I ordered a cam 2 years ago, I was told by bullet they had to search far and wide for a cam core for me. Stock connecting rods and crankshaft seems fine for the rpm capability of the motor (lack there of). The intakes and cylinder heads don't exactly fall out of trees, but they are out there. When I rebuilt the engine, it was not a "high dollar" rebuild, but it was all good parts. It's not a bad U/SA car to bracket race, but is more competitive in V/SA. I wouldn't be surprised with enough cash and time it could be a .75-.80 under combo in V. Would be neat to see one built with a third pedal. I was close to doing that, but went the v8 route instead. BTW for those curious, I had a vacuum gauge on the car for a few runs. Pulled about 7-8 in. of vacuum at the top end with that tiny carb. Fun fact the dimensions are the same as one hole of an 850 holley.
1189 F/SA Defunzalo Racing Enterprises |
#68 |
Liked 169 Times in 53 Posts
Afew years back I ran a 82 Monte Carlo in U with a 267/ It was factory rated at 115 hp, but Nhra saw fit to bump hp to150 without even seeing what could be done with it.Stated out with15.0 and eventually got it to run fairly consistent 14.40's and 50's. Best I ever ran was 14.20 @90 in killer air at No Problem. This was not a money is no object car but had good parts in car and engine.I felt that hp on engine was too high and that it should have been around 135 or 140 at start , then s ee how it turns out.Sure enjoyed running car and if things played out right would like to run it again but there's no way I feel like it's a 1.30 or higher car.
Bill Bogues 4696 STK |
#69 |
It treated me quite well. It would need more HP back to make it a "hitter" in the 21ST Century but it is a good, dependable combo that would probably respond well to a metric or a 4 speed. You can have cams made that will "make" compression (cylinder pressure) but, in the end you're still dealing with a 210 CFM carb..
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 09-27-2023 at 08:58 AM. |
#70 |
Liked 1,354 Times in 413 Posts
Gees 210 is a little guy. I like your line Billy. Might have to call you General Nees. Fun stuff this U/SA class. How is the average doing on the 302 this year?
Paul Haszlauer |
