#11 |
Liked 187 Times in 58 Posts
The point is many on here have the same canned suggestions , many miss the facts of which there are many, I ,and others have went through all of them many times in the past.
If I just take two rule changes of which were many over the years that have led up to now which are the roller rockers ,and the valve springs ,I am hard pressed to remember nattering nabobs of negativism when those two rule changes were made as to what a few say will eliminate stock as if they even know ,rather that focus on the cost of stock eliminator cars of today' along with the fact of the age of the cars 50 plus years in some cases ,along with the ages of many of the racers that drive them a few on here seem to only be interested in casting there unwanted opinions . Everyone should have a say as to what they want to run , while we still can if we stay on the course of the way it is in stock very soon there will be no more stock because of the cost, and lack of the parts we need, not the lifters ,here are two strong indicators as to why Electric cars ,but even worse eBay facing fines of $1.9 Billion for allowing the sale of parts that violate the clean air act . If you think well it won't effect me you're wrong .Already vendors are scared to ship parts , even oil to certain states.
John Ancona 717 STK / SS Last edited by john ancona; 10-05-2023 at 11:48 AM. |
#12 |
Liked 1,032 Times in 283 Posts
As I was in teardown at the Keystones, a D1 racer had Lonnie's ear about a multitude of topics, among them were roller lifters. I am not to tell you what that racers stance was on them, but I will tell you Lonnies take on it. Lonnie said he is not gonna open that door and allow them. He said as soon as he did that, many racers would be buying new roller profile cams, and would open a whole cost to the sport. I think those who are waiting for the rule to change should come up with another plan, whatever that may be.
Duane Hoven 1342 SS/GT |
#13 | |
John Ancona 717 STK / SS |
#14 | |
Maybe you and Terry can call him and explain that he's all wrong about his thoughts. I'm guessing he has talked to racers/engine builders about this, because he was pretty quick to talk about it and knows its a topic that is on people's minds. Or maybe he reads classracer
#15 | |
If as a group of racers with the non roller cams that feel they want a change they can explain why there is the need to go to roller lifters to NHRA , as they have done in the past with the roller rockers ,and many other parts
#16 |
Liked 869 Times in 165 Posts
While Reher-Morrison builds some very impressive pieces that I could never afford, I'm not sure they're the place to go looking for advice on your stock eliminator engine. The statement “A low-tension valve spring and a heavy steel valve is the worst possible combination for high-rpm reliability" is very easy to say when you're running "Bracket 2" and can run titanium valves, retainers, and don't care about valve spring pressure. I'm sure David Reher would say running a Qjet and a stock intake manifold is also a terrible combination for high rpm reliability. I think the only logical solution here is for everyone in favor of the rule to just start running roller lifters in their cars, and when (more likely if) a tech inspector sees a car with a roller cam that isn't supposed to, just threaten a lawsuit against the NHRA. At that point it must be their fault that they aren't going to allow you to run parts in your engine that you spent good, hard earned money on, and they will change the rule accordingly. OR, you just fix whatever problem you have with your engine, and run flat tappet lifters like the rest of us.
1189 F/SA Defunzalo Racing Enterprises |
#17 |
Guest
Posts: n/a
Here we go again
#18 |
Liked 7,912 Times in 1,755 Posts
If as a group, Racers who are sick and tired of all of the "upgrades and enhancements" that have made it more "convenient" for them to run an Eliminator called STOCK supposedly because the cars that run in it are supposed to be feel they want a change they can explain why there is the need to go back to 1990 rules to NHRA .
#19 |
Liked 165 Times in 60 Posts
Bubski is thinking the title of this post should be changed from "flat tappet lifter failure " To " Failure to Communicate " or better yet "Failure to communicate anything other than nonsense " Cheers Chums !!
#20 | |
Liked 373 Times in 129 Posts
