Old 10-13-2023, 06:41 PM   #1
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Default McClanahan DQ in Dallas
Does anyone know what Ryan McClanahan was DQed for, in the pre race all star inspection.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 10-13-2023, 08:11 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: McClanahan DQ in Dallas
Heard it was wheel base.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 10-14-2023, 08:15 AM   #3
Liked 10,966 Times in 2,260 Posts
I always thought the All Star pre race inspection was a correctable inspection.
Old 10-14-2023, 08:24 AM   #4
JeremyDuncan
Liked 355 Times in 80 Posts
They checked Stock and SS Wheelbase after Rd 1 of All Stars.
They Checked after Q2 Carbs, throttle bodies and pumped modified cars.
JeremyDuncan is offline   Reply With Quote
Old 10-14-2023, 01:36 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
Sounds like Wesley must have worked the event...
They allowed me to correct the wheelbase at a Memphis division race. Problem was I had a front suspension falling apart.
Lucky for me they checked the wheelbase. Rolled the car forward and it got short... Rolled the car back and it got long...
Adger Smith (Former SS)
Old 10-14-2023, 01:56 PM   #6
Keith 944
Keith 944's Avatar
Curious, what would the advantage be in a longer/ shorter than stock wheelbase be? Or is it possible offset? Rollout?
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-14-2023, 02:24 PM   #7
Adger Smith
Keith,
Extended roll out if one side is offset.
How is it offset?
One side at wheelbase specs minus allowance and the other side offset farther would be great for rollout.
You could go the other way too. one side a lot shorter.
Cover the beam as long as possible.
Start the clocks with the wheel the farthest back and stop the clocks at the finish line with the wheel most forward.
Make your side of the track shorter than the other guys... Simple, Aye
Old 10-14-2023, 03:42 PM   #8
If the rear end is not straight with the frame rails the front tires would have to be staggered for the wheel base to check correct. "Maximum variation from left to right: 1 inch."
Old 10-15-2023, 11:10 AM   #9
Barry Polley
Guest
Posts: n/a
They are stock suspension, they move big time. I saw this not more than a month ago on a new 4 wheel alignment. What I measured was not what it showed us! ! I was off an inch!
These cars are getting hammered round after round with wheelies. It will not stay!
I assumed it was the stocker, i missed!
Old 10-15-2023, 12:35 PM   #10
Ty Kwaiser
Ty Kwaiser's Avatar
Liked 33 Times in 11 Posts
What you state Barry may be true for 50+/- year old stockers but the front wheel drive conversion superstock/modified cars are built with a stagger to improve rollout. The purpose-built chassis does not move like the old stuff.
Ty Kwaiser is offline   Reply With Quote
