Old 11-06-2023, 11:59 AM   #11
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: 16 Volt Batteries? Best? Longest lasting?
rock batteries are far from the best. What is the best with the Rock name on it is their the battery charger, same charger as the Moroso and both manufactured by Interacter https://interacter.com/
Old 11-09-2023, 03:35 PM   #12
Tom Nolan
Liked 64 Times in 11 Posts
Does anyone make a 16v load tester? What usually happens is the battery will show 16v but by the time I get to the starting line two batteries will barely have enough to crank and make a run. Voltage but the amperage is gone.
Tom Nolan is offline   Reply With Quote
Old 11-09-2023, 03:56 PM   #13
1320racer
1320racer's Avatar
if your batteries are only showing 16v when fully charged, they're done and need replacement.
Old 11-09-2023, 05:38 PM   #14
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
My Turbo Start 16V battery would get so hot you could barely put your hand on it. I scraped them out soon after.
Dyno is online now   Reply With Quote
