Old 11-28-2023, 04:28 PM   #11
FSA1673
Liked 12 Times in 6 Posts
Default Re: 1968-1972 GM A Body Bump Steer Kit
The Global West steering arms lower the outer tied rod by about 5/8" actually making bump steer worse with stock suspension components. They may work with control arms that allow large degrees of caster. In my case I went from 1/4" to 1/2" toe change per side with those arms.
FSA1673 is offline   Reply With Quote
Old 11-28-2023, 10:49 PM   #12
Gmirza
Liked 253 Times in 95 Posts
You may need to bend the outer tie rod arms up or somehow lower the inner tie rod. If you take some caster out it should raise the outer tie rod ends. Bump steer can be very difficult to correct.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 11-29-2023, 08:21 AM   #13
FSA1673
A GM A body is front steer. Adding positive caster raises the outer tie rod.
Old 11-29-2023, 09:54 AM   #14
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Have you spoken to other A body racers with Alf’s suspension pieces like Jason Line or Kevin Borgstrom?
