I had a torque converter loosen up. I believe it was torqued properly, and I used blue loctite.
Should I use the red, or is there a better product?
Art Leong 2095 SS |
I use the red, never had a problem with nuts/bolts loosening with it
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Liked 14 Times in 11 Posts
I want to know also. I've used red loctite on convertor bolts and
then had to use heat to break the seal when I needed to remove the convertor.
Phil Saran Parker, Colorado |
Red holds a lot better than blue, but you will have to heat it up to get them off. I would think that a lock nut and the blue stuff would be enough, but if not the red will for sure hold them on there.
I use ARP bolts with Loctite Blue and never had a problem...however...in your application with a high RPM 4-Cylinder, you have more harmonics and vibration than a V-8 engine. Larry Morgan, when he ran his 4-Cylinder Fiero with the 151-CID Super Duty Pontiac engine, had the same problem with flywheel bolts loosening.
Liked 54 Times in 18 Posts
In the 70's I ran an H/G Anglia with a 300 Ford 6 in it. I tried red locktite, safety wire. extra dowels etc. Every 6 runs you had to replace the broken bolts. I never could get them to stay in. Theyd either back out or break the heads off. Wisk I could help, I know thats not what you want to hear. Its just a harmonics problem I was told.
Liked 4 Times in 1 Post
You might try using a larger diameter bolt, especially if your existing bolts are 3/8" dia. or less. Drill the flex plate and/or converter tabs for 5/16", make sure the clearance around the bolt is fairly snug. Worked for me once.
Tony Curcio 1860 STK |
I used the red or the blue depending on what size bolt and the amount of torque required. Never had to heat the bolts for removal. Very small amounts of red go a long way. I believe that coating a part of a couple threads is all that's required. This is how I fastened my flexplate. Never became loose, never had to heat to remove. And I went 8400 rpm or more, small block. Be conservative with this stuff. Jesse
Jesse Knapp 4899 STK, SS |
Are you using a bolt that fastens to a threaded boss on the torque converter or are you using a nut and a bolt that goes through the converter and flywheel?
I am a firm believer that if a fastener is engineered correctly for the application you shouldn't need any Locktite at all. There is a lot more to engineering fastener applications than a lot of guys think and pretty much take for granted. A bolt should have the proper stretch for the application among other things like the type of material, torque, etc. Talk to the experts at ARP they will ask you a lot of questions and get you the proper fastener for your particular application.
Nelson Kowal Stock 345 |
Liked 16 Times in 11 Posts
Here is a good question on Locktite, why is it $25-30 a bottle ? Is it made with a gold additive ?
Bob Pagano A/SA |
