Old 12-19-2023, 12:27 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default head to intake mismatch
Racers,
I have heard the stories of running a BBC rectangular manifold on an oval port head, which is a huge mismatch. The stories relate how such a mismatch ran well.
My situation is an LS3 head with a CDI intake that fits fine except the roof of the port. The port is about .080" smaller than the intake, at the top only. The engine is assembled except for the intake. If necessary, I can tape up and slightly the relive the top of the port.
My question: do I need to relive the top of the port, or is it wasted time?
Old 12-19-2023, 12:30 PM   #2
Woodfin
Default Re: head to intake mismatch
By tha way, this is a 408 CI drag race engine, NA, carb., with expected output of around 725 horse on Methanol.
Old 12-19-2023, 01:01 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
If I were in your shoes I would epoxy the intake to match the head.
Mike Pearson 2485 SS
Old 12-19-2023, 01:31 PM   #4
Woodfin
Mike, that is a reasonable idea, thanks.
Another thought, the CID intake is very tall and has a very large plenum. I have considered selling it and using a super victor.
This engine is going in a 75 vette and the CID intake will require a sizable scoop to clear.
Old 12-19-2023, 06:01 PM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by Woodfin View Post
Racers,
Larry, I say no. That said, I think you know I ran that mismatch for years, using an Edlebrock RPM dual plane manifold atop my then 650+HP 468 and it ran great. Rich Biebel aka scdiv1 over at DRR built the engine and did the fitment of the manifold. Ultimately a Brandywine aka Larry Woodward, fully ported Weiand single plane manifold ran .about 02 quicker. Best Et with the dual plane was 10.11 and single plane was 10.07 in better air.
Old 12-20-2023, 07:44 PM   #6
prostockpete1
Liked 90 Times in 52 Posts
I worked at a engine shop in the 70.s & we took a GM aluminum BBC Rectangular manifold & filled bottom of the runners with epoxy & then matched up to oval port heads .. made more power than any other existing oval port manifold avail at that time
prostockpete1 is offline   Reply With Quote
