Old 12-22-2023, 04:09 PM   #1
Frank Castros
Liked 2,798 Times in 983 Posts
Default Optimum Temperatures
What is the desired temperature for both Water and Oil for maximum performance? Also how many racers are using an Oil temperature gauge?
Old 12-22-2023, 05:00 PM   #2
prostockpete1
Liked 90 Times in 52 Posts
Default Re: Optimum Temperatures
Frank ... you should of asked how any use a oil pan heater to maintain oil pan temp thuout the days racin
prostockpete1 is offline   Reply With Quote
Old 12-22-2023, 05:37 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 986 Times in 314 Posts
Hot and cold........... I think you can figure out which one likes what. And yes on temp gauge
Old 12-23-2023, 12:50 PM   #4
SSDiv6
There are many variables as regards to the weight of the oil in use, and synthetic vs Dinosaur oil. Synthetics have a higher tolerance to heat.
Also, the block material has to be taken into consideration. The material expansion between a cast iron block and an aluminum block is different also and it will affect the piston ring sealing.
Based on what I have observed in the dyno and discussions with others, the general temperature guidelines at the staging lanes are as follows:
Water 110° ~ 120°
Oil: 170° ~ 180°
Old 12-23-2023, 01:09 PM   #5
Billy Nees
Liked 7,925 Times in 1,760 Posts
I was told by a very wise man a long time ago, "Billy you want the top of the engine freezing and the bottom melting!".
Billy Nees 1188 STK, SS
Old 12-23-2023, 09:24 PM   #6
Larry L.
Liked 4 Times in 1 Post
0W10 100% Ester base oil will perform well and won’t have to be very warm at all to it. Just my opinion.
Larry L. is offline   Reply With Quote
Old 12-25-2023, 09:03 AM   #7
Liked 11,032 Times in 2,267 Posts
An Arkansas definition from some FE Ford folks. “ You want the top turd cold and the oil like turpentine.”
Old 12-25-2023, 01:52 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Arkansas??
Old 12-25-2023, 02:06 PM   #9
Eman
Liked 133 Times in 76 Posts
Water 110° ~ 120°
Oil: 170° ~ 180°
I'd like to know how to achieve those temps. If I cool the water the oil follows, no way to get oil to stay 180*
Old 12-25-2023, 04:39 PM   #10
SSDiv6
Oil pre-heater in oil pan and if you have an engine diaper, it helps too.
