Old 12-27-2023, 02:24 PM   #1
Frank Beasley
Liked 32 Times in 19 Posts
Default ATI Supercase
I have a Rossler 350 Turbo that I busted the case on. We switched everything into a ATI Supercase but are having trouble with it. It is stuck in 2nd or 3rd gear and does not change when shifted. It goes into park, reverse and neutral with no problem. Any one run into a problem like this?
Frank Beasley
(828)234-5753
Frank Beasley is offline   Reply With Quote
Old 12-27-2023, 02:42 PM   #2
KennyAnderson
Liked 359 Times in 120 Posts
Default Re: ATI Supercase
Not with that case in particular but we had issues with an ATI glide case. It kept burning up the front pump bushing. After talking to a major trans player and my converter builder, he has had issues with those cases with core shift. We switched everything to a Dedenbear case and zero issues since.
KennyAnderson is offline   Reply With Quote
Old 12-27-2023, 02:52 PM   #3
Liked 1,892 Times in 423 Posts
Frank Beasley
(828)234-5753
You Rossler valvebody may not be compatible with the ATI case. Rossler stuff works, but some of it is absolutely a brand of its own. Not knowing which gear it is in kind of makes it hard to even guess.
Old 12-27-2023, 07:19 PM   #4
ss chief
Liked 48 Times in 13 Posts
Check that the valve location is where it needs to be.
I had to heli-braze about .100 to get valve where it needed to
be in relation to the valve body.
ss chief is offline   Reply With Quote
