Liked 19 Times in 17 Posts
Removing leaf springs and 70’s sliders from Chevy2 wagon super stocker. Ladder bar car weighing 1635lbs on the rear. Need spring recommendation rating for coil over. I already have coil over shock without springs. Thanks.
Ed |
Contact Marty Rinehart at Rineharts Performance.
Liked 354 Times in 120 Posts
110 on mine with just under 1500 on the rear. Tom
Tom Meyer 5240 SS Stock ??? |
Liked 1,966 Times in 595 Posts
Makes a difference with the length of the shocks. Longer shock’s less spring rate.
Mike Pearson 2485 SS |
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
I can get you what you need. Call me at Rineharts Performance. 717-793-6819
Marty Rinehart Jr 1125 SS STK SG SC SST |
Liked 925 Times in 263 Posts
Rear spring rate is a tuning decision. Typically, there will be 3 or 4 different rate springs that will hold the car at the desired ride height, with different amounts of compression and energy stored to get there..
Lighter springs with some energy stored by being compressed will make it easier to get the housing out and apply the tire than heavier springs. Just as a light spring compressed to hold ride height on the front will promote separation. Torque, stroke, gear ratios, trans type, tire type, suspension type, are a few of the things that play into that decision. |
Thanks everyone. Marty has springs on the way to NC.
