Old 01-08-2024, 02:08 PM   #31
David Lee
Liked 346 Times in 126 Posts
Default Re: Accusump - pros & cons
Originally Posted by 1320racer View Post
Frank, not my learning curve, my race engines are built by Professionals, the best in the industry. That said, even the best built engines, loaded with the best parts can and do have failures. Meanwhile, I put hundreds of passes on my engines a season unlike typical stock/super stock engines that don't see 100 passes.
My son has no interest in stock eliminator at this time, if he did I would have ordered a COPO long ago.
then why comment on a subject that does not effect you. And i think that just about everyone has professionals build their engines. and wee do not care about your racing
Old 01-08-2024, 04:01 PM   #32
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Of course you do and I do because I too have an opinion just as anyone else that has replied and how does an accusump affect you?
Old 01-08-2024, 04:23 PM   #33
David Lee
are you racing in stock or super stock?
Old 01-08-2024, 05:32 PM   #34
1320racer
1320racer's Avatar
Again, the pros and cons of using an accusump is an Engine conversation and not exclusive to engines being used in stock and super stock cars.
Old 01-08-2024, 05:47 PM   #35
David Lee
we do not care about your opinion
Old 01-08-2024, 06:13 PM   #36
1320racer
1320racer's Avatar
WRONG you don’t care and speak only for yourself and I don’t care about your opinion!
Old 01-08-2024, 06:26 PM   #37
David Lee
i have not given an opinion because i have zero experience with them. But you seem to know about everything that is known to mankind
Old 01-08-2024, 07:11 PM   #38
JGrossijr
JGrossijr's Avatar
Liked 460 Times in 59 Posts
David Reher of Reher Morrison:
"One of the best investments a sportsman racer can make for a wet-sump engine is an oil accumulator such as an “Accusump.” An oil accumulator is a sealed cylinder that contains a floating piston. Pressurized air on one side of the piston forces a reserve supply of oil into the engine if the flow from the internal oil pump is momentarily interrupted. An accumulator works automatically and requires virtually no maintenance except regular cleaning. Unfortunately, accumulators are seldom seen in drag racing. That’s a pity, because they really work."
https://rehermorrison.com/tech-talk-...-engine-alive/
JGrossijr is offline   Reply With Quote
Old 01-08-2024, 11:59 PM   #39
CMcAllister
Liked 920 Times in 259 Posts
Accusumps work well for their intended use. Cranking an engine before starting is still running parts together that may or may not be dry from sitting.
Cams, lifter bores, bearings and rocker gear with high spring pressures don't give a damn what class they are being used in.
Band aid or not, an Accusump can be useful with shallow, front sump, flat bottom pans and/or high G forces. Likewise, full oil galleys and oil where it needs to be before the engine is cranked does make a difference.
Don't like 'em, don't use 'em.
CMcAllister is online now   Reply With Quote
Old 01-09-2024, 06:26 AM   #40
1320racer
1320racer's Avatar
So how many stock/super stock racers here engines are built by Reher Morrison? Answer...NONE! So you can quote DR but he's not good enough to trust with your engine. Hypocrisy at its best!
Nuff said
