Old 01-09-2024, 06:54 AM   #41
JGrossijr
JGrossijr's Avatar
Liked 460 Times in 59 Posts
Default Re: Accusump - pros & cons
Interesting
Originally Posted by 1320racer View Post
Again, the pros and cons of using an accusump is an Engine conversation and not exclusive to engines being used in stock and super stock cars.
JGrossijr is offline   Reply With Quote
Old 01-09-2024, 10:51 AM   #42
Signman
Liked 269 Times in 99 Posts
Frank, not my learning curve, my race engines are built by Professionals, the best in the industry. That said, even the best built engines, loaded with the best parts can and do have failures. Meanwhile, I put hundreds of passes on my engines a season unlike typical stock/super stock engines that don't see 100 passes.
My son has no interest in stock eliminator at this time, if he did I would have ordered a COPO long ago.
LOL!!
Old 01-09-2024, 11:08 AM   #43
Mike Mans
Liked 299 Times in 48 Posts
Originally Posted by Jason Shepard View Post
How much additional oil do you need to run? 2 qts?
In our Moroso 3qt accumulators, they basically carry an additional 1.7qts I think. That's with the required pre-charge pressure and a system that runs around 55psi of oil pressure.
Mike Mans is offline   Reply With Quote
Old 01-09-2024, 11:11 AM   #44
SBillinson
Liked 183 Times in 48 Posts
A wise man once said: An ounce of prevention is worth a pound of cure.
There is no downside to an accusump.
On my car, I have a single stage external pump plumbed to a good pan with a sump that's almost completely covered and baffled. Oil pressure drops at the stripe if I don't immediately kill the engine.
Apart from an accusump, I "waste" my money on coated bearings and racing oil.
On an expensive, professionally-built racing engine that turns 10,400 rpm pass after pass, I "foolishly" spend a few hundred more on parts that any professional builder would consider a good idea.
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 01-09-2024, 01:22 PM   #45
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
There is, it doesn’t fix the root cause of low oil pressure which is due poor oil control. Hence it’s a band aid and should call into question one’s choice of engine builders IF said low oil pressure on deceleration and/or braking is a real concern.
That said, you and anyone else that choses to do so, need not justify your decision about your program to anyone and can “foolishly” spend your $ on and installing an accusump and it affects no one here but this thread isn’t about you and isn’t about an engine that turns 10,400rpm either!
Last, I have yet to have any professional engine builder tell me, suggest to me, that I need to use an accusump with their engine,
Old 01-09-2024, 01:33 PM   #46
SBillinson
Suddenly, I'm reminded of another saying.
“Never argue with a fool. They'll drag you down to their level and beat you with experience.”
SS/BS 1921
Old 01-09-2024, 01:35 PM   #47
1320racer
1320racer's Avatar
Says a fool that thinks he knows
Old 01-09-2024, 02:44 PM   #48
Mark Ugrich
Liked 71 Times in 38 Posts
Maybe you should have Mr. Reher build you an engine…….
Old 01-09-2024, 04:13 PM   #49
1320racer
1320racer's Avatar
Mr. Reher hasn’t built an engine in years and I have no need for his services as my engines are built by 2 of the best in sportsman drag racing engines.
Old 01-09-2024, 04:37 PM   #50
David Lee
Liked 346 Times in 126 Posts
Logical fallacy, even if he has not built any in years does not discount his expertise. and who are these "mystery" builders?
