Old 01-14-2024, 09:10 PM   #1
nickh
nickh's Avatar
Liked 656 Times in 197 Posts
Default Cryogenics
So I do not run a stocker or in SS, and know many people cryogenic treat rearend gears. Anyone do this with their blocks, cranks, rods?
But have the utmost respect for you guys and what you are doing. What are the pros & cons? How expensive is it to do? My bracket Nova had the gears done by previous owner, he never told me how much.
Old 01-14-2024, 09:21 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Cryogenics
Nick, it's not worth it for a stocker, much less a bracket car. Most engine builders will tell you don't waste your $. Years ago I tried coatings on the pistons, chambers and other parts against the advice of my engine builder at the time Tracy Dennis aka Sunset Racecraft. He was right, wasn't worth the cost and nothing on the dyno or time slip. My 3rd members are now done by Wayne aka Indy Gear and the R&P is Cryo'd, cost was $75
Old 01-14-2024, 10:23 PM   #3
SBillinson
Liked 183 Times in 48 Posts
I welded a set of aluminum heads and sent them to 300 Below for cryo. The heads machined better and were much harder than as cast. The heat affected areas on the deck where super hard and gave my surfacer a work out.
I have three aftermarket cast iron blocks that I'm sending to cryo because, in part, I want them a little harder. I do have to weld two of them. Cryo strengthen not only the weld, but the transition between the weld and base material. It also stress relieves the part.
I have a set a pistons that I need profiled for a new chamber. I don't expect much material to be removed from the dome, but nevertheless will send them to cryo for good measure.
The bottom line: Cryo works. I wouldn't think twice about doing a crank, but don't know if I'd do a set of rods. I also wouldn't hesitate to do a set of rockers.
300 Below charges by the pound.
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 01-15-2024, 10:54 AM   #4
Jeff Stout
Liked 706 Times in 283 Posts
We found the same thing with cryo heads. The cleaned up better and held up better with alot of nitrous
Old 01-16-2024, 12:12 PM   #5
Stickshift
Liked 30 Times in 12 Posts
I will never ever run a flat tappet cam and lifters without a cryo treatment ever again. The cam and lifters look so much better that for the money there is no sense not doing it.
Back when I was dealing with cheap dirt track racers we sent out EVERY cast crank for cryo, along with brake rotors. The cranks went from half a season to 3 years. And I only took them out because I figured they saved enough we didn’t need to chance it.
Brake rotors…I forgot how much longer they went but IIRC the cost break down was the savings in a year paid for the next two years of brake parts.
Cryo works.
Stickshift is offline   Reply With Quote
Old 01-16-2024, 12:14 PM   #6
Stickshift
Stockers and bracket engines are the guys who SHOULD be doing cryo. It’s relatively cheap and the life span of the parts (plus the added toughness) far outweighs the cost.
Doing blocks makes the ring seal better, although I’ve only done two blocks and since I retired I’ve lost track of those blocks. You could see the ring seal was better on the blowby meter.
Old 01-16-2024, 04:47 PM   #7
rx dealer
Liked 53 Times in 13 Posts
works great on valve springs too.
rx dealer is offline   Reply With Quote
Old 01-16-2024, 07:15 PM   #8
1320racer
1320racer's Avatar
PAC, PSI and Peterson all sell springs that are polished, which provides longer spring life than unpolished and all I’ve used for over 20 years.
Nick, I suggest you call and ask Scott Duggins aka PAR, Joe Jolly aka Sunset Performance, Phil Oakley aka Oakley Motorsports, Alan Bracey aka The Race Shop and Joey Hessling aka APD, the 5 biggest names in sportsman bracket, super classes, top sportsman and top dragster engine builders in the country about cryo for your bracket engine.
