Old 01-15-2024, 07:18 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default Tilberg shortblock, Misc LS, SBC, race parts
Tilberg low compression 350 shortblock
Crower 5.7 rods 2.125 with .875 pins
BME pistons, total seal rings
Crower crankshaft
Crower 903 tie bar lifters with .810 wheels
comp cam
$6500.00
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $400 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends – used but good condition – $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $150
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Trend (qty 17) – 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $150
Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $150
JRI 2010-2015 Camaro front struts $1000.00 used.
1 – Lingenfelter billet steel LS block girdle, No hardware $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
Jesel Dogbone lifters LFD-44002 – set of 16 – 1500.00
LS Bryant crankshaft – 4” stroke – 2800
Carillo rods 6.1 rods - 1200.00
ATI/Coan converter
This converter was manufactured by ATI, but freshened and rebuilt by Coan. Turbo spline, 8" steel with Square cut L Stator (35 degree), C Pump. We never ran this, but previously was ran behind a 255HP 350 combination.
$500
ATI converter
Flashed 6500 behind 427/430 LS Combo – 8” Powerglide spline - $500
7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00
Wilson 1” 4 hole aluminum tapered spacer – Dominator flange PN 024110 - $150 used for test only
MSD - Ford HEI Distributor cap and hold down PN 8408 NEW - $40.00
Energy suspension Poly engine mounts for SBC PN 3.1114G NEW (pair) $75.00
Biondo RPM2 shift controller – 2 LCD bars are inactive, but still legible to program - $100
SBC Polished fabricated valve covers with baffles tall - $100.00
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
Search this Thread:
Advanced Search
