Old 01-26-2024, 12:56 AM   #1
Mike Gray
Mike Gray's Avatar
Liked 695 Times in 201 Posts
Default Need help with coil springs
I finished my 67 Shelby build last week and fired it up. It’s now down off jack stands and I changed the trailer tires to my Hoosier 27” front tires. It looks fantastic except the front bumper is now below my knees. I’m not as tall as certain Mopar racer so this is a real problem. I bought the Moog front springs years ago and can’t find my notes but they measure up the same as the 8088 springs. Most of the 60’s Ford stuff is discontinued so what are some of you big block mustang racers using to get the headers out of the weeds?
8088’s are 259lb inch with 1540 load.
Mike 7570 A/SA
Mike Gray is online now   Reply With Quote
Old 01-26-2024, 02:27 PM   #2
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
Default Re: Need help with coil springs
You can call Marty Rinehart for springs. Landrum springs are the go to for alot of Fords. Probably gonna need 200s to 250s, but Marty will be able to help you with that. He will ask you for the weight on the front of the car, so if you don't have it, you should try to borrow a set of scales.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 01-26-2024, 05:47 PM   #3
Ralph A Powell
Liked 225 Times in 136 Posts
Eaton Spring Corp on has all the Blueprints for Ford Front and rear leafs? Just Google them.
Old 01-27-2024, 12:15 AM   #4
Mike Gray
Mike Gray's Avatar
Thanks for the spring info.
I hate to change the “stance” but 2” of clearance doesn’t work.
Mike 7570 A/SA
Old 01-27-2024, 08:30 AM   #5
Liked 10,792 Times in 2,244 Posts
Looks like you need a skid plate underneath the oil pan. With the 3.993”stroke it going to get up in the air, it’s the falling back to earth that scares me. Good luck it looks great.
Old 01-27-2024, 06:24 PM   #6
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Randy at Fastshocks has a new front shock setup for the Mustangs, give him a call!
Old 01-28-2024, 11:20 PM   #7
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Mike, give me a call during business hours and I’ll help you out if you still need it.
717-793-6819
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is online now   Reply With Quote
Old 01-29-2024, 11:04 PM   #8
Mike Gray
Mike Gray's Avatar
New springs on order, Thanks guys for the help.
Mike 7570 A/SA
