Old 01-29-2024, 07:56 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Ford coyote softplugs and oil plugs
Working on a gen coyote with new cylinder heads. None of the galley plugs for oil or water are in them. Not having much luck finding sizes or plugs.
Anyone have a parts list or kit number for these plugs
Thanks
Mike Graham is offline   Reply With Quote
Old 01-29-2024, 08:52 PM   #2
partsbob67
Liked 79 Times in 11 Posts
Default Re: Ford coyote softplugs and oil plugs
according to the parts catalog for a 2017-2023 5.0 head the big plugs are 32mm, and the small plugs are 12mm.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 01-29-2024, 09:13 PM   #3
Mike Graham
Bob
My post was not clear. My bad. This is a 2014 gen1
Plugs that I can see that are missing.
Front and rear oil galley plugs. 2 are threaded and 2 are press in.
There are 4 plugs in the heads between camshafts.
Front and rear water plugs.
Is there a blowup of those plugs?
Thanks
Mike Graham
Old 01-29-2024, 10:53 PM   #4
BillK
Liked 30 Times in 17 Posts
Mike,
Should be easy enough to measure the holes for the press in plugs. Almost certainly will be Metric on that engine. Screw in plugs will probably be 1/4" or 3/8" pipe ? You can go to Ford Parts online and look at the parts for a 2014 Mustang and it should show them.
Bill Koustenis
BillK is offline   Reply With Quote
Old 01-30-2024, 10:17 AM   #5
SSDiv6
Liked 1,604 Times in 583 Posts
Hi Mike,
This is the kit you need.
https://coyotedirect.com/products/bp...1-2020-mustang
