Old 02-01-2024, 04:35 PM   #1
prostockpete1
Liked 90 Times in 52 Posts
Default GM sportsman Bow Tie sbc block question
late 90.s GM Bow Tie Sportsman sbc block question .. engine still in car how do I tell if it is a 1 or 2 piece rear seal .. i see the aluminum seal plate behind the crank flange in photos of BowTie blocks in GM catalog but no other data telling me if a 1 or 2 piece without disassembly .. has typical 6 bolt crank flange .. thanks
prostockpete1 is offline   Reply With Quote
Old 02-01-2024, 05:27 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,944 Times in 585 Posts
Default Re: GM sportsman Bow Tie sbc block question
They do come both ways.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 02-01-2024, 07:13 PM   #3
prostockpete1
Yes Mike I know both blocks come both ways .. thats my question how do I identify with out disasembly without pan off .. is the aluminum seal plate blocking a way of knowing 1 or 2 piece without teardown ?
Old 02-01-2024, 07:36 PM   #4
Mike Pearson
If it has the aluminum seal plate then it is a one piece seal block. The two piece does not use that aluminum plate. You can run a 2 piece crankshaft in the one piece blocks with the adapter. The work fine.
Old 02-01-2024, 08:01 PM   #5
prostockpete1
Mike .. so how come on the GM perf parts site both photos of sportman blocks have aluminum seal plates for 1 & 2 piece
Old 02-01-2024, 08:03 PM   #6
prostockpete1
so mike how come on the GM perf parts website they show photos of both BowTie block part # .s of 1 & 2 piece with aluminum seal plates
Old 02-01-2024, 08:28 PM   #7
Mike Pearson
If it’s a one piece seal they still have a plate. The two piece adapter bolts to the same flange and has the groove for the two piece seal. That way you can run a 2 piece crankshaft or the one piece crank in those blocks. I have one bow tie block that is for a two piece seal only and it does not have a plate. It has a standard rear main cap. You can only use a two piece seal crank in that block.
Old 02-01-2024, 09:00 PM   #8
L.Fite
Liked 497 Times in 243 Posts
can you see the flange on the crank?
L.Fite is offline   Reply With Quote
Old 02-01-2024, 09:14 PM   #9
prostockpete1
yes can see flange ..its scalloped around one side of 3 bolts & regular curved edge along where dowel pin would go
Old 02-02-2024, 12:33 PM   #10
Eman
Liked 133 Times in 76 Posts
If it has a flange a one piece seal can't slide over it.
