Old 02-16-2024, 06:50 AM   #11
Henrys Toy
Liked 520 Times in 176 Posts
Cool Re: Crap, th350 emergency
No. 2nd gear clutches are attached the case ,behind the front pump. No band necessary for forward motion.
400s work similarly for 2nd. They do have a band for lo/rev , rather than clutches though.
Good morning to all,
When I first read the post I thought that a lip seal might be the cause, but since it had reverse before, Marks comment on the frictions is probably pretty close to the source of the problem. The TH250 has a" Band Apply" for second gear as does the THM200. I would drop the pan and inspect for friction material and anything metallic. If there is a lot of debris in the pan, I'm not an advocate of running all that junk through the trans and possibly jamming up a valve in the valve body or ruining the rest of the frictions in the trans. This is why a good many racers have Spare transmissions with them. Take a look and go from there. Good luck on your Quest.
Respectfully,
Henry Kunz 1534 H/SA
P.S. Check with other racers and see if someone local can help look at the trans. G.M. built those transmissions by the thousands - meaning there's stuff around that might be able to get you through the weekend.
Last edited by Henrys Toy; 02-16-2024 at 06:54 AM. Reason: need to add additional information
Henrys Toy is offline   Reply With Quote
Old 02-16-2024, 08:59 AM   #12
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
Default Re: Crap, th350 emergency
Originally Posted by Mark Ugrich View Post
If it’s there, the band is manual 2nd. correct?
The band is only used used “2” shifter position on a factory trans/valve body to allow compression braking in that gear/position. No other purpose. Class race trans should have it removed.
Kp
Old 02-16-2024, 09:11 AM   #13
Rob Petrie E395
Liked 216 Times in 77 Posts
Don’t know if it’s your problem. But with my TH350 and PPP shifter. If the cable is not adjusted exactly right. I get no reverse. Even if it’s off a tiny little bit. Probably not your problem. But it’s easy and quick to check.
Old 02-16-2024, 10:03 AM   #14
Roy Kinslow
Liked 127 Times in 27 Posts
Since it's an emergency as a last resort.... I knew a person with an old ford that would lose reverse , they always carried a bottle of Lucas Transmission Fix. Put some of that in and would be ok for a while . Maybe it raised the pressure and viscosity a bit, I don't know but they swore by the stuff.
Roy Kinslow is offline   Reply With Quote
Old 02-16-2024, 10:34 AM   #15
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Old 02-16-2024, 11:16 AM   #16
Jim Cimarolli
Liked 166 Times in 46 Posts
I have seen this happen a few times. Most people only put one or two reverse frictions in a footbrake transmission like yours. When you tear it down I think you will find the reverse clutches welded to the plates and all the lugs knocked off the clutches. We all know a person is not going to burn up reverse backing out of a pit area. However, if you often shift it into neutral after the run and your shifter is a bit out of adjustment that's how this happens.
Jim Cimarolli is offline   Reply With Quote
Old 02-16-2024, 02:35 PM   #17
JP1738
JP1738's Avatar
Liked 1,225 Times in 343 Posts
Unhappy Re: Crap, th350 emergency
Thank you all so much for the input! I’ve got lots of good advice to take into account in the future, including just having a spare.
High gear is completely gone now. No reverse, no high. I shifted into high on the first qualifying run this morning and had nothing. I’ve got a beat on another trans to pick up on the way home. I’m still gonna go up there for first round as 1 and 2 are still totally solid. A very very disappointing first event, but I’ll fix it and be back in 2 weeks! This class racing thing has been unbelievably humbling. Managed a 14.12 off the 13.00 with no 3rd gear.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 02-16-2024, 03:15 PM   #18
1320racer
1320racer's Avatar
Old 02-16-2024, 06:21 PM   #19
L.Fite
Liked 497 Times in 243 Posts
Ya know...
My mom told me if I didn't have anything nice to say, to just not say anything.
L.Fite is offline   Reply With Quote
Old 02-16-2024, 08:09 PM   #20
JP1738
JP1738's Avatar
Originally Posted by 1320racer View Post
Only because of the way you chose to try and compete.
You got 100k laying around for me to buy a FS/# car with? Me neither. Go make your own thread where you pick on guys doing their best with what they have. I built what I could afford, and with some help from friends, I’m dam proud of it. I think you’ve lost what the spirit of drag racing is.
Also, to be fair, you said I’d never make a lap in NHRA competition with a car I build. Wrong. I showed up, put it in the beams knowing I couldn’t win. I did it anyway. Go pound sand.
Those that have helped, encouraged, and offered advice, I appreciate it. Y’all still have the spirit of what this is. Thank you.
Dawson Pauley
