#11 |
Liked 759 Times in 379 Posts
nor do I but he did
#12 | |
#13 |
Liked 59 Times in 13 Posts
I, and several other Comp racers I know run their Type F trans fluid with great results. Looks the same coming back out as it did when new, plus all the clutches, bands, gears, etc. look pristine. Like you, I run Maxima every where else on the car but give Amalie props for how well their trans fluid works. I have ran other brands with a much higher cost that did not perform as well.
#14 |
There is no better trans fluid than Allison's Transynd, try it and you'll be glad you did.
#15 |
Liked 1,032 Times in 283 Posts
I ran transynd for years, and I agree its a superior fluid. Joel is pretty adamant about running Type F, and Eddie Horensky is also, so I switched over. I have my trans gone thru every year and it still has the same clutches from 300 runs ago when we put the pro trans gears in it. So so far so good.
Duane Hoven 1342 SS/GT |
#16 |
Dwayne my trans in both my cars get freshened every other season, with north of 400 passes and they always look brand new. Keep in mind with the dragster, that's across the line burnouts, 5200rpm launches and sub 1 second 60 foots. Further, with Transynd, the fluid temp runs cooler by at least 10 degrees.
#17 | |
Liked 1,865 Times in 435 Posts
james perrone 1290 STK |
#18 | |
Guest
Posts: n/a
Exactly! He doesn’t race class. Pro trans does not like Synthetic fluid. Transmission tolerance and clutch material dictate fluid spec. These aren’t bracket cars! I cannot see your reply just what others are saying.. so don’t bother . |
#19 |
Liked 2,768 Times in 980 Posts
Oh yeah he does, it's Top / Fool.
#20 |
super comp and super street runs 1/4 mile.
![]() Last edited by 1320racer; 02-17-2024 at 02:04 PM. |
