Old 02-21-2024, 07:23 AM   #1
Wrenchead
Default Car on lift
I found a first gen Mustang that has been resting on a two post lift (8ft. In the air) for at least ten years. The car was solid before being raised. It is also in a dry garage.
Will being on a lift for at least ten years negatively impact the structure of the car?
Wrenchead is offline   Reply With Quote
Old 02-21-2024, 08:46 AM   #2
Liked 11,012 Times in 2,263 Posts
Default Re: Car on lift
I would not think so. If it’s suspect take it to a frame shop and have them put it on the numbers. That way you have a good starting point.
Old 02-21-2024, 09:05 AM   #3
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
On those cars if the doors open and close nice all is well.
Old 02-21-2024, 09:14 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
8 feet or 1 foot, no difference, suspended by 4 contact points on the frame. Should be no issue though after 10 years, I’d swap out the shocks, bushings and springs
Old 02-21-2024, 09:28 AM   #5
Woodfin
Liked 288 Times in 109 Posts
I think it will be fine. If it is a complete, uncut car, it has plenty of structure to hold it stable. Also, look over all the sheet metal including the roof. Any buckling would be obvious.
Old 02-21-2024, 10:37 AM   #6
Wrenchead
Thank you for the suggestions.
