Old 03-03-2024, 02:30 PM   #1
goinbroke2
Liked 398 Times in 157 Posts
Default water pump drive vs electric pump
I need a new water pump drive, already got a brand new shorty aluminum pump and went to order the moroso kit..$177.00US???? WTH?? Used to be $79.00 last I looked, now close to $300Can for an electric motor and cogged belt?? Really??
I looked at SBF electric water pumps and they are $150.00 for the cheap and $600 for mezier or whoever.
This thing only has 200hp or so, so the stock pump with kit will work, but what would people recommend?
Is the no name electric water pump at Jegs or Summit any good? Or is there another drive kit available? I even tried to get the pulleys and belt seperately and can't.
{{{{{{{Biggest question is, electric water pump or stock pump with electric drive?}}}}}}}}
Old 03-03-2024, 03:29 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: water pump drive vs electric pump
All you need is the drive motor which is a blower motor and it’s available at any decent auto parts store. You just need the part number which I no longer have.
Old 03-03-2024, 04:25 PM   #3
Rory McNeil
Jim, I have a couple of Mr. Gasket/Moroso electric water pump drive kits in the garage, PM me.
NHRA 6390 STK
M/S 85 Mustang
Old 03-04-2024, 08:07 AM   #4
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
https://www.cvfracing.com/ford-289-3...-35-gpm-black/
I would go electric pump, less to go wrong, no belt. And cleaner install.
Pat Clemente
#1427 B/S
427FE is offline   Reply With Quote
Old 03-04-2024, 11:17 AM   #5
goinbroke2
Message sent.
Old 03-04-2024, 02:46 PM   #6
1legjerry
Liked 72 Times in 15 Posts
The belt drive on a stock pump will get you around 5-10 GPM. Even the cheap electric pump will flow more like 20-35 GPM. But at 200hp the belt drive will likely work fine. The higher flowing pump would help you cool down between rounds faster.
1legjerry is offline   Reply With Quote
Old 03-04-2024, 04:22 PM   #7
340Cuda
Liked 805 Times in 341 Posts
Easy for me to spend your money but I would go with the Meziere pump.
Old 03-06-2024, 10:50 PM   #8
Jack McCarthy
Liked 477 Times in 117 Posts
budget for two electric pumps ....gotta have a spare
with the moroso kit trip tp napa and your in business
capt
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 03-07-2024, 08:57 AM   #9
curtis reed
Liked 125 Times in 59 Posts
If you have one of the 12v motor belt driven pump set ups and want a better motor that will turn a couple hundred rpm more my company sells these that we use in our centrifuges. They are way better than the smaller 12v motors used in the kit. We do have those also but they would cost more from us I would expect. Here is the better one we sell.
https://www.wlwalker.com/Product-Det...productId=3056
curtis reed is offline   Reply With Quote
Old 03-07-2024, 12:00 PM   #10
68Coupe
Curtis how much are those motors that you sell
68Coupe is offline   Reply With Quote
