Go Back   CLASS RACER FORUM > Class Racer Forums > Competition
Old 03-08-2024, 12:47 PM   #1
Frank Castros
Liked 2,750 Times in 971 Posts
Default Joshua Lee
What engine combination does Joshua Lee run in his H/EA?
It looks like he has a Honda logo on the scoop.
Old 03-09-2024, 02:17 PM   #2
Charles Stewart
Liked 755 Times in 213 Posts
Default Re: Joshua Lee
I think he still use a Honda engine.
Here are 2 old photos of his set-up and a small video.
Charles Stewart is offline   Reply With Quote
Old 03-09-2024, 09:56 PM   #3
FED 387
Liked 333 Times in 180 Posts
Josh uses a Version based off a F20c Honda engine---these came in the Honda S2000 used from 2000-2009--FED 387
Old 03-11-2024, 11:27 AM   #4
Charles Stewart
Now just for the fun of it, I play here with some “theoretical” numbers from his set-up.
The H/EA minimum weight is 1100 lbs with 8, 25 lbs per cu.in. giving us an engine of 134 cu.in. (utilizing the minimum weight)
Index is 9, 56 sec. and Joshua Lee have a personal index of 9, 52 sec. He own the record at 8, 84 sec, (04/11/23) at 150 mph that is giving 0, 72 sec. under the index and 0, 68 under his personal index. You need 424, 63 H.P. (Wallace racing E.T and MPH calculator) to do it.
(3, 17 H.P. per cu.in.)
Now, let applied this set-up to the dragster class: L/DA. Minimum weight at 850 lbs and 7, 50 lbs per cu.in. Index is: 8, 85 sec.
134 cu.in. with 7, 50 lbs per cu.in., give 1005 lbs with 424, 63 H.P. (Wallace racing E.T and MPH calculator) give an E.T. of 7.77 seconds and 174.01 MPH. A whopping
1, 08 under!!!
Old 03-13-2024, 08:48 PM   #5
Frank Castros
The Honda F20C is a great design and a great choice for Competition Eliminator.
Old 06-04-2024, 11:27 PM   #6
Greenlight
Liked 79 Times in 22 Posts
Originally Posted by Charles Stewart View Post
Now just for the fun of it, I play here with some ?€œtheoretical?€? numbers from his set-up.
1, 08 under!!!
Are you suggesting that he makes 3.17 HP/cid ?
***Nitro Joe's indicates that he has a 146 cid engine. 146 * 8.25 = 1205 lbs. min. wt. ****
Greenlight is offline   Reply With Quote
Old 06-05-2024, 08:55 AM   #7
Charles Stewart
If you use the Wallace racing E.T and MPH calculator...
at 146 cu.in. at 8,25 lbs/cu.in.=1205 lbs., you need 465,16 H.P. for his 8,84 record run. That give 3,186 H.P. per cu.in.
http://www.wallaceracing.com/et-hp-mph.php
Old 06-05-2024, 01:33 PM   #8
Charles Stewart
Hi Greenlight, by the way`
I don't pretend that the Wallace racing E.T and MPH calculator algorithm is right on target.
So my reason of the part text "Just for the fun of it".
If you use the first tabloid on the Wallace racing E.T and MPH calculator and you introduce the weight 1205 lbs and the new calcul of 465,16 H.P., you will obtain and E.T. of 8,00 second. (So something is wrong somewhere)
And at the end, if you use the old Moroso Power-speed calculator, you will obtain around 335-340 H.P. for his record time of 8,84 sec. at 1205 lbs.
Definitively something to think...
Old 06-10-2024, 03:13 PM   #9
Rich67stang
Liked 116 Times in 27 Posts
When I ran H/EA with my 171 CI Trail Blazer Engine, I went 8.64 @ 1400# @ VMP. Joshua Lee has a great combo for H/EA.
Richard Preiser
1613 FGT/I 1510 C/SA 161 F/DA
Rich67stang is offline   Reply With Quote
Old 06-12-2024, 09:32 AM   #10
Charles Stewart
Very very good run with this set-up.
What is the base engine of your altered ? a 2,5 liters ecotec ?
